05 deville sunroof leak...had enough
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 05 deville sunroof leak...had enough in Past Cadillac Vehicle Discussion; Tried weedwacker line. No success. Rear drains fine. Its the front two that are clogged. Weedwacker line stops near wheel ...
    sleepymarks is offline Cadillac Owners Member
    Automobile(s): 05 deville
    Dec 2009
    31
    12
    Tried weedwacker line. No success. Rear drains fine. Its the front two that are clogged. Weedwacker line stops near wheel well. Hole in wheel well turns in at an angle. Any suggestions. Been fighting this for about a year. Very fed up. You can tell by my short sentences.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Have you removed the plastic wheel well liners, and checked for a clog at the rubber outlet grommets?
    Trench's Avatar
    Trench is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Eldorado (Gone) ; 2001 Seville SLS (RIP) ; 2005 DeVille
    La Salle County
    32
    228
    Re: 05 deville sunroof leak...had enough
    I do not have sunroof and have never seen what type of material these drain lines are made of, so this may not be a good idea if they are weak/flimsy.
    But how about a blow gun and an air compressor? give it a few quick bursts and hopefully dislodge the clog.
    Dec 2009
    31
    12
    Ive removed the flap but i dont see any "grommets" pictures would help incredibly.
    Quote Originally Posted by Trench View Post
    Cant use compressed air due to the flimsy tubes. Thanks though.
    Sep 2010
    East Boston MA.
    29
    26,325
    I don't have a picture or diagrams, but they look like pinched tubes.
    68
    81,917
    Dec 2009
    31
    12
    That helps a lot! Thanks! Looks like I'm probably getting stuck at the bottom where 18 and 16 meet or in the weird turn in 16.
    68
    81,917
    Can you locate the end of #18 and maybe go in from there?
    Dec 2009
    31
    12
    Tried but that first turn in 18 is too much of an angle
    70cougar is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 DTS, 70 Cougar conv
    Dec 2009
    Connecticut
    723
    I've used low pressure air several times on mine & it always has worked to clear front drain clogs without hurting the tubes. Maybe I've been lucky, but using wire, etc. never worked so I went with air.
    68
    81,917
    Compressed air is an option, but it's also a gamble. If the clog is bad enough (it shouldn't be) that it won't budge, then something has to give when the pressure gets high enough and that something would probably be where the drain hose attaches to the sun roof up top. If that happens, you have much bigger fish to fry. If you try the compressed air, do it slowly as opposed to a hard blast. Might even put a regulator on the compressor to keep the pressure low.
    Dec 2009
    31
    12
    I dont have an air compressor...guessing that the one at gas stations wont work?
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,632
    You're better off finding the flapper valves then. They get brittle, poor design IMO.
  16. #14
    Dec 2009
    Connecticut
    723
    That's what I do, using a regulator on my compressor set at no more than 10psi. Then I put the nozzle end in the upper hole but don't put it in tight, so if there is a hard clog the air can escape back around the nozzle. Again, this has worked fine a number of times, with no problem. In each case, it was clogged enough that I'd get water dripping inside when it rained.
  17. #15
    68
    81,917
    Yeah, it would stand to reason that it would not be a very hard clog. Just some light dirt and sediment.
    Another alternative if you don't have a compressor would be to fill the tube with water and use a squeeze bulb or turkey baster or such to "pump" water into the drain tube under a bit of pressure (hydraulics). Obviously you'll have to seal the opening in some way.
  18. Remove Advertisements
