heat help ?
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, heat help ? in Past Cadillac Vehicle Discussion; 2002 dts.. 4.6 northstar.. engine overheats, but heater blows cold.. any ideas would be most helpful.. im gonna switchout the ...
    sannerj's Avatar
    sannerj is offline Cadillac Owners Member
    Automobile(s): 2002 deville dts
    Apr 2013
    17
    heat help ?
    2002 dts.. 4.6 northstar.. engine overheats, but heater blows cold.. any ideas would be most helpful.. im gonna switchout the thermostat now.. but very doubtful that's the cause of overheating. electric fans are working as per norm. stumped here..
    69
    82,382
    Re: heat help ?
    You have air in the system. Start by checking the purge line for coolant flow. Do a search for purge line if you need help. Been discussed a gazillion times.
    sannerj's Avatar
    Apr 2013
    17
    Re: heat help ?
    hmm.. nothing but steam comes out the purge line
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Have you checked the coolant level??
    sannerj's Avatar
    Apr 2013
    17
    Re: heat help ?
    yes sir,its right on the mark,, I was able to blow thru the purge line, no clogs there..engine heats up really fast, as well.. I just bought the car used, has 172xxx miles on it. ran really good when I drove it home
    Sep 2010
    East Boston MA.
    29
    26,323
    Blew through the purge line from which end? And that's not really the best way to check for clogs.
    sannerj's Avatar
    Apr 2013
    17
    Re: heat help ?
    blew thru the fill tank end.. ***update: just found a crack below the hose, in the radiator, ( pass.side) I guess i'll be switching out the rad. along with the thermostat.. got em both out, just need to run and get parts. anything I should pickup while im at the parts counter (autozone) ? arrgh.. hope it doesn't drag on much further..
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,848
    Re: heat help ?
    Quote Originally Posted by sannerj View Post
    you SHOULD be getting a constant - gentle flow of coolant -
    from the engine - to the serge tank - through the PURGE line -
    sannerj's Avatar
    Apr 2013
    17
    Re: heat help ?
    yes sir, I noted that, basscatt.. im thinking the whole problem was the crack in the radiator, causeing air buildup. im gonna go ahead and do the thermostat also, as the old one looks factory.. well, it seems pretty old. I thank you gents for your input.. stay tuned, i'll update after its all back together.. ps) gonna do an oil change as well.. should be all set to go after this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    Re: heat help ?
    Thermostats are pretty reliable for these engines. use the original AC Delco unit which starts at 188 and is fully open at 206.
    Use the annotated temp gauge picture in my albums for reference. The Community tab ^^^, Albums. The red Seville - 2 albums, 120 pictures and diagrams of stuff for the 2000 - 2004 FWD Northstar cars.
    sannerj's Avatar
    Apr 2013
    17
    Re: heat help ?
    many thanks folks,, thermostat... radiator... all new coolant... oil change. seems to be back to normal, after a 55 mile drive. ***except***... now my "service engine soon light" is on.. hmmm... any idea's as to where I might find an owners manual..? 02' Deville, DTS
    69
    82,382
    Re: heat help ?
    Ebay is your friend for an owners manual.
    To find out why the SES light is on see the DTC Sticky at the top of the forum page.
    sannerj's Avatar
    Apr 2013
    17
    Re: heat help ?
    duely noted, ranger. thanks
  16. #14
    sannerj's Avatar
    Apr 2013
    17
    Re: heat help ?
    checked the codes sticky.. no longer open. I have a code... IPM BO429 showing.. any idea's ? thanks
  17. #15
    Caddy-EaRL's Avatar
    Caddy-EaRL is online now Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    737
    It's for your rear air controls. Here's a nice thread...
    http://www.cadillacforums.com/forums...ipm-b0429.html
  18. Remove Advertisements
