88 deville rough idle with heater or ac on
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 88 deville rough idle with heater or ac on in Past Cadillac Vehicle Discussion; i'm currently battling a rough idle like many other 4.5s. no codes. in econ mode the idle is smooth and ...
    normllikeme is offline Cadillac Owners Member
    Automobile(s): 1988 Sedan Deville
    Mar 2013
    33
    10
    and only happens with the a/c or heater on (more like a surging perhaps)..
    a/c clutch engages/disengages alot
    any thoughts?
    thanks
    68
    82,076
    Re: 88 deville rough idle with heater or ac on
    Heater is completely unrelated.
    Surging sounds like a vacuum leak.
    A/C clutch engaging and disengaging is normal. The interval will depend on temperature and humidity. Is it providing cool air?
    Mar 2013
    33
    10
    ya both the heat and a/c work normally. haven't found any vacuum leaks yet but i guess i'll check again
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    Depending on how quickly the AC is cycling it can be a sign of a low charge. With AC running there's additional load on the engine, that's probably what the difference is you're noticing. A tune up might improve it a bit if it's been a while.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    We'd need a better description, but if the heater and AC are being used in "auto" mode, the compressor is being cycled. That's more load on the engine, which the isc should be adjusting for. It may be inop, since you mention the symptoms don't appear in "econ" mode. Do the symptoms also appear when turning the steering wheel?
    Mar 2013
    33
    10
    did plugs/cap/etc recently.
    and yes now that mention it i think it does act a little off when i'm turning the wheel...i have thought about snagging a new isc motor (i'm hearing a bit of a rattling type noise from the area, just wasn't sure if it was the isc or throttle body)
  9. Remove Advertisements
