Electronic control unit for 1993 sedan DeVille
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Electronic control unit for 1993 sedan DeVille in Past Cadillac Vehicle Discussion; I have another ECU for my '93 Caddy Sedan Deville. It has a "cleaned up: chip in it. I had ...
    cortezit is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    6
    Red faceElectronic control unit for 1993 sedan DeVille
    I have another ECU for my '93 Caddy Sedan Deville. It has a "cleaned up: chip in it. I had Harris Performance Products burn a chip for me which removes all of the "Programing anomalies". I have it installed in a spare ECU. My problem is that I do not have a book which tells me where the ECU is located. I removed the glove box and looked at the 2 ECU units there. I think that one is for the SRS and the other for the ABS. Am I right. If so where the heck is the main control unit located at??
    cortezit
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Remover the passenger side hush lower panel . And towards the back there is a 10mm nut remove it push the ECM/PCU up and then lower it you may want to un plug the connectors first.
    Mar 2008
    6
    Re: ELECTONIC CONTROL UNIT FOR 1993 SEDAN DEVILLE fwd
    I found it last night. It is called a Power Control Module in the Mitchel book, I subscribed to that service way back when and had forgotten about it. I took down the module and changed it out with on (same exact number) and the reprogramed Harris Performance Chip (tbichips.com). He had done a chip for me on a custom TBI setup that I was running in a Chevy pickup so I asked him (Brian Harris) if he could do something with the Cadillac and he said yes.
    I have noticed that it is crisper on the throttle since the install. We will see what it does for fuel mileage. I get 24.5 now with it on our road trips to California from Northwest Washington State. Thanks for getting back to me on this.
    cortezit
    Dec 2005
    288
    The nerve of Mitchell book calling it a different name and to think us Old guys call it a computer.
    Mar 2008
    6
    It was probable a twitter tweet that caused them to change it. What ever happened to the hand crank telephone?
  8. Remove Advertisements
