code RIM C 0658
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, code RIM C 0658 in Past Cadillac Vehicle Discussion; Recently i had this level control compressor circuit high. It is history not current. The car had been up on ...
    purelux is offline Cadillac Owners Fanatic
    Automobile(s): 2003 deville
    May 2011
    487
    code RIM C 0658
    Recently i had this level control compressor circuit high. It is history not current. The car had been up on a lift and rebuild kits on tpms and i think bat was disconnected about a week ago. Would this meen the compressor needs replaced?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    Re: code rim c0658
    Test the ELC system ............ pop the trunk, turn the Key: ON. After about 6 seconds do you hear the compressor do its preload/checkout for a second or two ?? OK ?? Good - now you and 2 assistants sit on the open trunk lip. Does the compressor again come on and level the car? OK - Now all hop off and you listen for escaping air in the RR wheelwell. if this all checks out, then the system should be OK.
    If not, time to start checking the level sensor connector rod(s), the compressor electrical connectors, relay, fuse(s), air lines, shock bladders.
    May 2011
    487
    It does it's pretest ill check if its inflating with a load. The rod is connected and i used electronic contact cleaner and dilectric grease on its connector. Air lines and dryer and monroe shocks are new. Compressor is newer from a 2005 about 60k on it.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Re: code rim c0658
    if it was me -
    I would simply clear the code - and see if it comes back -
    May 2011
    487
    That's what I was thinking too. So far I've been able to check everything except the compressor plug itself. I did forget when my front rotors were installed 2 weeks ago it was only lifted by a floor jack and turned on to turn the wheel.
    May 2011
    487
    Thanks everything checked fine and now the history is gone.
  9. Remove Advertisements
