Fuel gauge pegged
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Fuel gauge pegged in Past Cadillac Vehicle Discussion; Current code; P0463- Fuel Sensor Circuit High Input. Just started this last night. can this be anything other than replacing ...
    Cadygrl's Avatar
    Cadygrl is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4, 156km, 2000 DTS, Northstar, 160,000K
    Oct 2011
    Winnipeg, Mannitoba, Canada
    40
    137
    Fuel gauge pegged
    can this be anything other than replacing fuel gauge sensor?
    Thanks for input....
    Ken
    68
    82,070
    Re: Fuel gauge pegged
    I'd put my money on the level sensor.
    Feb 2003
    california
    69
    6,663
    I'd put my money on a disconnected wire to the sender. Normally when a GM car has an open connection to the tank sender, the gauge pegs to full.
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    670
    Quote Originally Posted by carnut
    Slim chance wire has disconnected. Them suckers are hard to get off even when you're trying lol
    Feb 2003
    california
    69
    6,663
    I don't mean unplugged, I mean cut, broken somewhere from the dash gauge to the sender.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It's most likely just the sender. Fairly common failure.
    Cadygrl's Avatar
    Oct 2011
    40
    137
    Hi Guys; I'm trying to put up a picture, but for some reason I can't make it happen. I picked up a new fuel level sensor and have the fuel lines and plugs disconnected. I have the ring off, but I can't get the assembly out of the tank. Its a hair to big to fit through the hole. Is there something I'm missing?
    Thanks....
    Ken
    Cadygrl's Avatar
    Oct 2011
    40
    137
    I've been struggling with this for a couple of hours. A couple of pointers would be great.
    Thanks....
    Ken
    scanssystems's Avatar
    scanssystems is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac DHS; Galaxy Silver 252k
    Mar 2012
    New Jersey
    701
    You just have to play with it. 3 minute task. It is hard to put it back too. Just make it happened. No tweeks here.
    Caddy-EaRL's Avatar
    Apr 2013
    Ky
    51
    670
    Quote Originally Posted by Cadygrl
    Thanks....
    Ken
    I just changed mine is morning. It's typical for the plastic to get malformed a bit over the years being submerged in gas. What I do is pull it up and out a bit one side, then take a small pocket screwdriver and work the other side out by prying on it between the pump and tank neck. Putting it back in wont be difficult at all, it will drop right down.
    Cadygrl's Avatar
    Oct 2011
    40
    137
    Thanks for the tips. I finally got it. I was afraid I was going to break it. Got it out, cleaned it, put the new sensor in it and stuffed it back in. You were right Earl, it fell right in. Works perfect.
    Thanks...
    Ken
    littlewolf is offline Cadillac Owners Member
    Automobile(s): 2003 deville
    May 2011
    3
    I may need to change my sensor as well on my 2003 deville. I have no code but my gauge acts erratically after about 9.3 gallons used.Do i need to relieve the fuel pressure in the lines or is removing the filler cap enough for this job.
    68
    82,070
    You need to relieve the line pressure.
  16. #14
    May 2011
    3
    Thanks. I guess I'll have to get a fuel pressure gauge with a bleeder valve.
  17. #15
    68
    82,070
    No, all you need to do is wrap a towel around the service port to absorb the oz. of gas that will come out and press the schreader valve (just like letting the air out of your neighbors tire). Simple as that and the system is depressurized.
    Or, pull the fuel pump fuse and crank the engine.
  18. Remove Advertisements
