94 Deville CV Joint possible issue
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 94 Deville CV Joint possible issue in Past Cadillac Vehicle Discussion; While driving home last night, I started hearing this loud clicking noise by the driver side front wheel. It does ...
    jvickerm is offline Cadillac Owners Member
    Automobile(s): 94 deville
    Apr 2013
    41
    1
    While driving home last night, I started hearing this loud clicking noise by the driver side front wheel. It does this regardless if Im turning or going straight. I have put the car up on jacks and took the wheel off. I wanted to inspect the CV joint and the boots look fine. I had both front tires off the ground and decided to put the car in drive and try to see if I could pinpoint the issue. When I revved up the engine with car in drive I could clearly hear this clicking sound. I tuned the car off and started looking around and noticed some fluid leaking out of the point where the CV meets the transmission. Its not grease, more like a fluid. My question is, is this more than a CV joint? Is something wrong in the transmission?
    This is what the fluid looked like coming out of the cv joint.
    68
    82,081
    Re: 94 Deville CV Joint possible issue
    Sounds more like a trans seal. #14 maybe
    http://www.gmpartsgiant.com/Page_Pro...PartSortBy=Key
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    670
    It's not 14, that not even on the same side as the axles. It's more likely number 4. It wouldn't be cv joint grease coming out of the tranny, cv joint grease would come from the ends of the boot. So it has to be tranny fluid.
    68
    82,081
    Good point. #14 is a servo band seal. #4 isn't listed for some reason.
    EDIT:
    I see it is included with #6.
  7. Remove Advertisements
