Water leaking into the car
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Water leaking into the car in Past Cadillac Vehicle Discussion; Hello everyone and thanks for looking into the problem that ive been experiencing with my 2001 Deville DTS. Over the ...
    DevilleTouringSedan is offline Cadillac Owners Member
    Automobile(s): DTS
    Dec 2008
    24
    UnhappyWater leaking into the car
    Over the past couple weeks ive noticed that water is leaking through the passenger side pillar and running down through the tweeter and sometimes it comes out of the vent. I'm not sure if I should take out the headliner and silicon the roof at this time.
    Any suggestions to what I should do to fix this problem before I take the headliner down?
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    Re: Water leaking into the car
    How is the weather stripping, is the window sealed? I would look at those two.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Classic symptoms of clogged sunroof drain outlets. Not sure of the exact location on a Deville, but try doing a search.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,473
    if you have a sunroof -
    I agree 100% with MoistCabbage -
    plugged drain tubes -
    the best method to clear them is the thick weed-wacker string -
    GENTLY poked and prodded through the hose till the blockage is cleared -
    some have tried air pressure - and it works great -
    UNLESS you use a little too much pressure -
    and blow the hose off the fitting -
    Automobile(s): DTS
    Dec 2008
    24
    The weather stripping is fine and and the window is sealed
    Last week I cleared the one drain outlet on the passengers side of the sunroof but couldn't get to the opposite side drain outlet because the sun roof was in the way.
    Already picked up the .080 dia weed wacker line and ran that thru the line for about 2 feet. How do i know if its cleared?
    Do i just pour water down the drain tube and if it doesn't leak its cleared?
    68
    82,056
    Pour water down it and look for it dripping beneath the car or run the line down and look for it poking out beneath the car. What goes in the top, must come out the bottom.
    Automobile(s): DTS
    Dec 2008
    24
    Thanks everyone for the input
    Have a great weekend
    Sep 2010
    East Boston MA.
    29
    26,325
    The outlets are what get clogged. There are 4, one at the end if each tube. They resemble pinched hoses. If you pinch them open, sediment should come out, and the water should start flowing.
  11. Remove Advertisements
