99 Deville Tail Light Problem.
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 99 Deville Tail Light Problem. in Past Cadillac Vehicle Discussion; Posted this in the electrical subforum but not much as far as responses. Originally Posted by Eninety2 Is this a ...
    Eninety2 is offline Cadillac Owners Fanatic
    Automobile(s): 99 Deville
    Jun 2011
    37
    131
    Quote Originally Posted by Eninety2 View Post
    Is this a known problem? I always see them on the street and its the same thing. The top two bulbs work on both sides but the single bottom bulb is out on both sides. Changing the bulbs is only temporary. It'll work for a little while but then they go out again.
    Should I just change the pig tails?
    Still having this problem. I actually starting to doubt whether all three are indeed supposed to light up when braking or not. The weird part is the third socket and bulb is different than the top two.
    Regardless here is a pic of both the socket/bulb and housing.
    parking lights work, just not the brake or turn signals ONLY on the bottom/third bulb.
    If anyone can help, I would greatly appreciate it. I have spare entire housings and pigtails of necessary.
    Thanks!
    Mr.electric is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Mar 2013
    80
    Those little peanut bulbs burn out all the time. They should last a year or so. Something is wrong if they go out faster than that on a regular basis.
    Could be moisture on the bulb or something wrong with the circuit. Although I couldn't guess what could be wrong with the circuit that would cause a bulb to fry, it either has 12v or less than 12v.
    On second thought I have heard of alternators producing a higher voltage or an a/c voltage after a failure. Probably not your problem.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: 99 Deville Tail Light Problem.
    I don't think the bottom bulb functions as a brake light or turn signal.
    I'll have to double-check on mine, but that's what I remember.
    If it was used as a brake light and turn signal, the bulb would have 2 filiments inside.
    68
    82,076
    That is one nasty looking housing. Remove the bulb and see what the contacts in the socket look like.
    bigm57ict's Avatar
    Aug 2011
    Wichita Kansas
    44
    1,845
    I just confirmed on my '95: the bottom bulb of the three is a parking/running light only. No brake light or turn signal. Yours is most likely the same.
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    Time to swap that rear light harness for one not corroded. Flaky connections will be hard on bulbs.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    I agree, that's a nasty looking housing. The bottom one only lights up with the side markers. I also had one side burn up, but that's because the bulbs were old, The replacement I put there still works fine after 3-4 years.
  10. Remove Advertisements
