98 Deville ac compressor not kicking on
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 98 Deville ac compressor not kicking on in Past Cadillac Vehicle Discussion; Car has a full charge, both hi/lo pressure sensors are good, i feel the relay kick on and the fans ...
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    Car has a full charge, both hi/lo pressure sensors are good, i feel the relay kick on and the fans come on but the clutch doesnt engage. Any ideas? I'm at a loss.
    rodnok01's Avatar
    Feb 2012
    NC
    6,675
    Any codes?
    Check for power at the clutch. If so and still not locking up i'd say the clutch is bad.
    You've checked the pressures? Have you done any work recently.
    I would also unhook the battery & see if it'll lock up
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,581
    Re: 98 Deville ac compressor not kicking on
    Quote Originally Posted by STS_Seville_Hunter View Post
    like rodnok said - check for codes -
    did you check the fuses -
    what are the actual pressure readings - BOTH high side and low side -
    Sep 2008
    29
    675
    No codes, fuse good, it took two pounds in but unsure of pressure with out it running. Haven't checked power to compressor not feeling that much.into bdsm yet.
    rodnok01's Avatar
    Feb 2012
    NC
    6,675
    If you're dumping freon in and comp not running what's the point. You're gonna damage something is all.
    Need to jump the conpressor and have pressure checked. How could you know the low/high sensors are good or bad either.
    69
    82,190
    How are you getting it to take 2 lb without the compressor running?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,581
    I was going to ask the same question -
    you can not "pump in" 2 pounds of freon without the compressor running -
    what is the static pressure -
    Sep 2008
    29
    675
    Ac machine at the shop.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    If car has no a/c codes than compressor should start. Yes, low freon will set a code and not allow compressor to engage. OP only says he added freon. Does not say why he added freon. If he was low before, and he was if he added 2lbs, than he should have codes if he did not clear them.
    Slipgate is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Deville
    Jul 2009
    48
    710
    Jump the low pressure cutoff switch and see if the compressor starts/ac works. It is right near the firewall on the low pressure side (where you fill it - follow that tube towards the firewall). This is my problem as well. I am putting in a new switch tomorrow and hope that it is the switch. My system works perfect with the jumper switch on.
    I read that you do not need to evacuate the system to replace that switch. That is has a shrader valve underneath it.
    69
    82,190
    Any idea how much refrigerant was in the system when the 2lbs were added? Maybe it's overfilled and the high pressure switch is disabling it.
    Sep 2008
    29
    675
    1.x we vacuumed it out, will jump the switch tomorrow thanks for the suggestions as temps are already well into the 90's
  15. Remove Advertisements
