Wipers are dead
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Wipers are dead in Past Cadillac Vehicle Discussion; I have a 2002 DeVille DTS with rain sensing wipers. The wipers and washers do not work in auto or ...
    Cad_zilla is offline Cadillac Owners Member
    Automobile(s): 2002 dts, 1970 coupe deville
    Sep 2012
    PA
    52
    18
    Wipers are dead
    I have a 2002 DeVille DTS with rain sensing wipers. The wipers and washers do not work in auto or any manual position. I have checked the fuse under the hood (#3) and removed the wiper mechanism. After inspection, the motor appears to be fine. No visible damage to the circuit board. Is there any way to test the motor or the leads from the firewall to see if the problem is the motor or the switch? I am leaning toward the switch because the washer also doesn't work. This may be faulty logic though. I would appreciate any suggestion that may help me diagnose.
    68
    81,928
    Re: Wipers are dead
    My money is on the switch. There must be a way to jumper the motor to see if it runs.
    Sep 2012
    PA
    52
    18
    Does anyone know how to jumper the wiper motor? I disassembled the switch last night and could not find anything that looked faulty. I have a suspicion that it may be something other than the switch or the motor. I would like to confirm proper operation of one of them prior to replacing parts.
    Sep 2012
    PA
    52
    18
    I have a Haynes manual but it does not include the schematic for the wipers is there a source for this info? Couldn't find anything on this site.
    68
    81,928
    Re: Wipers are dead
    If you are going to continue to do your own wrenching, use the Chiltons manual to absorb fluids from your garage floor (same goes for Haynes) and get yourself a real FSM by Helm Inc. (Ebay is your friend) or a subscription to www.alldatadiy.com
  8. Remove Advertisements
