Help! Rough idle now after taking care to Firestone - 2001 Deville
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Help! Rough idle now after taking care to Firestone - 2001 Deville in Past Cadillac Vehicle Discussion; My ignition coil pack went out so i took it to the Firestone shop. They replaced the coil pack that ...
    magnumpi28 is offline Cadillac Owners Member
    Automobile(s): 2001 deville
    Apr 2013
    46
    My ignition coil pack went out so i took it to the Firestone shop. They replaced the coil pack that went out, but replaced all spark plugs too plus did the fuel service treatment.
    When i picked up my car the guy asked if i wanted to test drive my car and looked like a cat that just eat a canary(i thought that was odd) i said no, paid the bill and left. As soon as i got to the stop light i noticed a very very slight misfire about every 30-45 seconds.
    I took my car back and when i got the car they said it was a very small peice of carbon that got under a spark plug but they fixed it. They said this was caused by there wonderful fuel injection cleaning loosening the carbon.
    Then the service engine light came on and it said it was a air pump...Firestone said i needed a air pump and relay....i took it to a small auto shop and he replaced the air pump but said it didnt need a relay.
    However, My car seems to be running a little rough idle where before all of this it seemed to idle fine, the RPM seems fine, runs aroun1200-1275 then goes down to around 900 then around 650-675.
    The car is not pulling any codes yet.
    Its a 2001 deville with 130,000
    Can anyone tell me what i should have checked for a rough idle? Any help would be appreciated, i miss my smooth ride.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Re: Help! Rough idle now after taking care to Firestone - 2001 deville
    What was exactly done? What brand spark plugs did they use? Did they actually replace spark plugs? Sea-formed ("wonderful fuel injection cleaning")?
    68
    81,913
    Try a good TB cleaning.
    Apr 2013
    46
    They used NGK platnuium spark plugs and for the fuel service was a product called QMI, they said they use to use BG products but this is cheaper.
    wishmaster242 is offline Cadillac Owners Member
    Jun 2013
    1
    Did u ever get the rough idle fixed? I'm having same issue it's not all the time. And Firestone fixed my car also. They replace the idle air control valve , also the TPS throttle position sensor it's running no codes but everyone n a while it'll idle up and down. Can someone help me with this issue please.
    68
    81,913
    Update you profile to show your year and model so we know what we are talking about.
    Was the TB cleaned?
  9. Remove Advertisements
