Hood emblem replacement
Results 1 to 5 of 5
Like Tree1Likes
  • 2 Post By scanssystems
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Hood emblem replacement in Past Cadillac Vehicle Discussion; Got very good looking 01 crest for hood. Can anyone tell me how to remove old one? I don't get ...
    scanssystems's Avatar
    scanssystems is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac DHS; Galaxy Silver 252k
    Mar 2012
    New Jersey
    701
    Got very good looking 01 crest for hood. Can anyone tell me how to remove old one? I don't get how did they manage to bolt it down...
    customcafe's Avatar
    customcafe is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    65
    Re: Hood emblem replacement
    It is literally a twist and play attachment system. If you pop the hood, and find the bottom of the retainer clip (it is black plastic) you will simply need to unseat the retainer clip and twist. Replacement is just the opposite of taking the old one out. Good luck!
    Mar 2012
    New Jersey
    701
    Why should I twist? Is there thread?
    I looked through many threads and nobody ever explains how do they do it...
    Mar 2012
    New Jersey
    701
    DONE!
    Of course, I broke plastic clips but managed to install it anyway. Looks great! The way it suppose to be!
    Was:
    Now:
    And don't tell me double emblems look ugly. I love it to be doubled!
    Personally I hate modern crest. It is ugly and shapeless. I LOVE MY DUCKS AND CROWN! Keep it classic all the way!
    Mar 2012
    New Jersey
    701
    I see nobody really interested in this thread. Well, I saw lots of people had same question and nobody ever posted the answer. I'm here, I did it and I'm going to give the RIGHT directions to do it w/o any damage.
    I would say this is clean and easy dealers way. I'm going to disclose it here. I spent nearly one hour to figure it out and really now it is going to take no more than 5 minutes.
    Removing:
    1. Remove retaining ring using long pliers. Be careful not to break any plastic parts and not to loose ring.
    2. Using a flat screwdriver pry a little 2 black tabs which secure emblem in the place. BE CAREFUL NOT TO BREAK THEM!
    3. Doing step 2 try with your another hand to pull up the ornament. Release one tab(one side of ornament) a time. You will have to play with it.
    4. Once metal part has been removed you got plastic base "sitting in the hole"
    5. If you need just to swap crests you can disregard this step. Plastic base holds by 3 plastic tabs. You have to bend them inside slightly and pull up the base. Now you got naked hole.
    Installation:
    1. Insert metal ring onto the plastic base.
    2. Insert plastic base into the hood hole.
    3. Insert metal ornament into the plastic base.
    4. You done.
    Hope this helps someone one day.
    Cheers!
  8. Remove Advertisements
