Steaming engine
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Steaming engine in Past Cadillac Vehicle Discussion; Today we have 39 F and 92% Humid. After short driving I noticed on parking lot lots of steam coming ...
    scanssystems's Avatar
    scanssystems is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac DHS; Galaxy Silver 252k
    Mar 2012
    New Jersey
    701
    Steaming engine
    Today we have 39 F and 92% Humid. After short driving I noticed on parking lot lots of steam coming out from engine. Opened up and it looks like coming from radiator. Also radiator in sweat too... What's going on? Cold and humid weather? Engine dorsnt overheat, coolant level on point.
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    what type of car and engine do u have? did u pull codes...if do not know how look up at sticky to find out and post back.
    Mar 2012
    New Jersey
    701
    Regular 01 DHS.
    It doesn't come from radiator. It is hard to say from radiator cause when you look at that it just comes. It looks like from top rail of radiator.. maybe I'm wrong..
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Re: Steaming engine
    Steam smelling like coolant? What most likely happened is that the radiator side tank has given up and developed a crack after numerous heat/cool cycle throughout the lifetime of the car. Plastic radiator side tanks are almost like consumables, they will fail after enough cycle. It usually develops cracks under the hose attachment point, or the front side of the radiator, where you can't easily inspect them. Coolant will leak through the crack, and leaked coolant touches the hot radiator parts and evaporates = steam.
    Try to find wet spots when it is steaming, or when it cools down, dry white chalky residue (dried coolant) anywhere near the radiator side tank. If you find any of those, you need a radiator replacement.
    Mar 2012
    New Jersey
    701
    I don't know how coolant smells. But so far as this steam smells.. I can't smell it. It almost doesn't smell. But my best guess is coolant.
    Top rail have been wet due steam. Plus on the bottom on the splash guard I saw wet spots. About inch or two.. maybe less and few of them.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,598
    Re: Steaming engine
    Is the "steam" coming from the radiator - or the A/C condenser coil/fins which is in front of the radiator ?? If you had the A/C on it's possible that you see condensation evaporating off the condenser - far fetched, but possible....... and water condensation vapor would not smell like coolant.
    Mar 2012
    New Jersey
    701
    No, I didn't run AC because it was 39 degrees! I didn't run heater either.
    Where is AC condenser/coils anyway?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by "Submariner409
    ...or the A/C condenser coil/fins which is in front of the radiator...
    69
    82,177
    Re: Steaming engine
    I have (on very rare occasions) under conditions like you described in post #1, noticed a whiff of steam coming from the grill when sitting in a bank drive through, but your description of "lot lots of steam" would seem to rule that out.
    Mar 2012
    New Jersey
    701
    I will post video when I get home.
    Look here:
    http://www.youtube.com/watch?v=LK2a3yhCpDg&sns=em
    Oops.. sorry
    69
    82,177
    Re: Steaming engine
    THAT is NOT humidity. You have a leaky radiator. It must smell very sweet (coolant).
    Mar 2012
    New Jersey
    701
    Crap! Even yesterday everything was fine! How could it happened overnight? Damn! Are you sure I need a new radiator?
    P.S.
    Will do smell test on my way back home..
    Sep 2010
    East Boston MA.
    29
    26,325
    The side tank probably cracked, not uncommon. If you can't pinpoint the leak by the steam, rent a pressure test kit.
  16. #14
    Mar 2012
    New Jersey
    701
    But if its steaming it is radiator anyway, isn't it?
  17. #15
    Feb 2006
    56,598
    Re: Steaming engine
    Quote Originally Posted by scanssystems View Post
    Your radiator is toast.
    Look real hard at your 'radiator' - there are TWO "radiators" sandwiched together - the one nearest the grille is the A/C condenser; the one nearest the engine is the coolant radiator.
    In order to replace the coolant radiator you must separate the two parts. Carefully, coming out and going in: The condenser stays in the car and you do not want to bend or nick it.
  18. Remove Advertisements
