Steaming engine - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Steaming engine in Past Cadillac Vehicle Discussion; Originally Posted by Submariner409 Your radiator is toast. Look real hard at your 'radiator' - there are TWO "radiators" sandwiched ...
  1. #16
    scanssystems's Avatar
    scanssystems is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac DHS; Galaxy Silver 252k
    Mar 2012
    New Jersey
    701
    Quote Originally Posted by Submariner409 View Post
    Look real hard at your 'radiator' - there are TWO "radiators" sandwiched together - the one nearest the grille is the A/C condenser; the one nearest the engine is the coolant radiator.
    In order to replace the coolant radiator you must separate the two parts. Carefully, coming out and going in: The condenser stays in the car and you do not want to bend or nick it.
    Wow! Didn't know that! Thank you! There are two indeed!
    Did my trip back home.. No steam, no sweat, no water on the bottom of splash guard, no smell... 60 degrees outside and about 40% humid.
    Any ideas?
  2. #17
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    680
    Re: Steaming engine
    Before it started steaming the other day did you happen to go through a car wash with underspray, when I do mine steams for a while.
  3. #18
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,374
    Re: Steaming engine
    if you look closely at the video -
    you can see water/liquid on the bumper cover -
    did you just go through a car wash? -
    if NO - get a pressure test kit - rent it for free from the auto parts store -
    with the engine cold - pump the pressure up to 20PSI -
    look at the two black plastic side tanks of the radiator -
    that's the most common place to leak -
    if you do need a new radiator - here is a good source -
    http://www.partsgeek.com/5zyfhzh-cad...tor.html?fp=pp
    I would recommend the Spectra Premium CU2491
    $121.25 with free shipping -
  5. #19
    Mar 2012
    New Jersey
    701
    No car washes. But yesterday we had rain all day long and up and down temperature.. as well as humid.
    Can I use Mityvac pump? It is vacuum though...
    Water on the bumper because it was raining and crazy humid after that. My mirrors and glass were useless. Only wipers saved me.
    Saved me from humid evaporations, not rain.
  6. #20
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    You need to PRESSURIZE the system with a cooling system pressure test kit.
  7. #21
    Mar 2012
    New Jersey
    701
    You think I got a leak even after everything I said??
  8. #22
    Sep 2010
    East Boston MA.
    29
    26,325
    It definitely looks like too much steam to just be moisture burning off.
    Have you checked your coolant level?
  9. #23
    Mar 2012
    New Jersey
    701
    Coolant level on point and doesn't go away. I keep it half inch above mark. I will make some level marks with pencil just to make sure..
  10. #24
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Re: Steaming engine
    If it rained like crazy and it happened, then see if it still steams after a good drive on a dry day. Even a small drop of coolant is enough to make people around the car smell coolant.
  11. #25
    Mar 2012
    New Jersey
    701
    Drove it back home in sunny weather - completely dry inside out. No steam.
  12. #26
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Re: Steaming engine
    Then it was probably just rain water evaporating after hitting hot cooling system parts. Nothing to worry about.
  13. #27
    Mar 2012
    New Jersey
    701
    42 F and 80% humid today
    Drove again. No steam at all.
  14. #28
    68
    81,928
    Re: Steaming engine
    Must have been moisture on the radiator.
  15. #29
    Mar 2012
    New Jersey
    701
    I stick with this idea too. I don't wanna even think about new radiator. Nope. Mine is good! Think positive!
  16. Remove Advertisements
