Cloth top cleaning and repair
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Like Tree2Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Cloth top cleaning and repair in Past Cadillac Vehicle Discussion; Hi there Cadillac forums! My 99 devilles cloth top is starting to come loose at the sides... i was thinking ...
    mhswres1 is offline Cadillac Owners Fanatic
    Automobile(s): 1999 cadillac deville
    Jul 2012
    27
    115
    Hi there Cadillac forums! My 99 devilles cloth top is starting to come loose at the sides... i was thinking that silicone would work well to put it back into place?
    Also my cloth top gets really dirty, alot of birds around here.... are there any products made for cleaning cloth tops? The regular car was products dont seem to work to well
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    What do you mean by "loose at the sides"? Is there stitching that's falling apart? Binding? Or is it just lifting?
    Car wash liquid, and a soft brush should take off any presents from your flying friends. There are convertible top cleaning products, but do not use anything that "treats" the top in any way.
    Jul 2012
    27
    115
    Stiching had come undone mostly.. its not terrible and its just on side... as far as the vac goes theres to brushs on it... it kust sprays i mix of hot water and a soap onto it and then the vac part sucks it up., very strong vac
    You can lift ip the black cloth and see the roof
    Ill use car was soap instead of the other stuff
    Sep 2010
    East Boston MA.
    29
    26,325
    Once it starts falling apart, there's not much you can do. If you want to try an adhesive, go for it, can't hurt. Just be neat.
    I don't think the vac would do much, there would be no airflow through the material, it's glued directly onto a fiberglass form.
    Jul 2012
    27
    115
    If thats the case mine needs to be re glued as it lifts right up. You can see its not really glued any more
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Re: Cloth top cleaning and repair
    Silicone is not an adhesive.
    And once you get it in there there will be no going back.
    They make adhesives for that.
    Sisqosasha is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac DeVille
    Jan 2014
    8
    What is considered a product that "treats" the top that we shouldn't use. Is that like scotch guard? Also, how often should one wash their car? and do these intervals change in the winter?
    Thank you, I have a 2003 DeVille.
    Ray
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Quote Originally Posted by Sisqosasha View Post
    Ray
    YES - and anything like it -
    ah - when it gets dirty -
    EXCEPT if the temps are below zero -
    Sep 2010
    East Boston MA.
    29
    26,325
    Also, never use convertible top "treatment" or any water proofing products.
    And speaking of winter, never try to pull ice off of the roof. What I do is gently brush the whole car off with my arm (snow brushes leave all kinds of swirls and marks in the paint), then go to the DIY car wash booth, and use the high pressure rinse to wash/melt all of the stuck ice off of the roof (DO NOT put the wand closer than 6" from the material). Then I go through the regular car wash so the roof gets dry. Otherwise it will be shiny and rock hard when it freezes.
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    57
    379
    get the problem at the source, bird shot 12ga.
    CadillacLuke24 and DJLogsdon like this.
    DaKing214's Avatar
    DaKing214 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    35
    56
    If you want to try an glue it back, try to find a gallon of the Dap Weldwood Contact Adhesive Landau Top & Trim. How about using some Haartz Raggtop cleaner and protector?
    Sep 2010
    East Boston MA.
    29
    26,325
    I have a gallon of weldwood. EXTREMELY strong stuff.
    Cleaner is fine, "protector" and "treatment" products is what you want to stay away from.
    2002CarriageTopDevil is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Jan 2014
    none
    41
    81
    some of th bubble are approx 1 feet diameter.
    Quote Originally Posted by 2002CarriageTopDevil
    this morning i noticed my carriage has some air bubbles, i am thinking of cutting a little incision and spraying some adhesive in there. any thoughts?
  16. #14
    Sep 2010
    East Boston MA.
    29
    26,325
    You'll never get full coverage, and you'll just end up with several smaller bubbles, and possibly lumps/waves in the fabric.
    The material has to be peeled back, the old adhesive cleaned off, the correct adhesive sprayed on, and the material stretched taut and stuck back down. ~$200/$300.
  17. #15
    Jan 2014
    none
    41
    81
    thanks for the info, if i can get a pro to do it right... i will... i was gonna drown the fabric with adhesive, and hope they stick.
    i m afraid its gonna get worse and rip right off on the highways if ignored.
    i think parking it outdoors did this...
  18. Remove Advertisements
