Question - 1993 Deville idle relearn
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Like Tree6Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Question - 1993 Deville idle relearn in Past Cadillac Vehicle Discussion; I unhooked the possitive battery cable so the compressor would not run while changing tires.it started right up but hesitates ...
    padgett1963's Avatar
    padgett1963 is offline Cadillac Owners Member
    Automobile(s): 93 sedan deville
    Sep 2012
    Adams WI
    53
    28
    I unhooked the possitive battery cable so the compressor would not run while changing tires.it started right up but hesitates on start for about 10 seconds then runs fine.never done that before.that's what the local Chevy garage told me to do.can someone give me a clue why my car. 93 sedan deville runs like crap at start up....thanks. Richard
    aeronca36606 is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Coupe Deville 4.1 V8 & 4.3 V6 Deisel & 1970 Eldorado
    Sep 2005
    East Tennessee
    773
    Re: Question
    By disconnecting the battery you dumped the ECM's memory. The ECM will need to relearn all of it's fuel correction tables. This will take a few days of driving. I used to have a dodge mini van that took 2 weeks of running before it would run smooth again after a battery disconnection.
    Sep 2012
    Adams WI
    53
    28
    Re: Question
    Will everything be ok after that? Is that why it starts and runs like crap for the first 10 sec.this is a great car and the only other problem I have is the keyless entry don't work. Bought it that way but the security light flashes when I open the door but that's for another day.thanks
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    28
    26,325
    It's just going through an idle relearn. There's a quick way to do the relearn, it should be explained in your owners manual.
  6. #5
    68
    81,723
    Re: Question - 1993 Deville idle relearn
    Have you checked the FPR? If it's leaks down after shut down, it just might be running rich and burning off excess fuel. A leaky fuel injector could have the same effect.
  7. #6
    Sep 2012
    Adams WI
    53
    28
    I cannot find anything in the book about it.it still runs and drives great.never had a problem before..will it work itself out if I keep driving it? Can I add a fuel additive on a fill up to clean the inside of Motor up or no.like I said it runs fine.thanks.Richard
  8. #7
    68
    81,723
    If there is something wrong, it will not heal itself. If it's an idle learn problem, yes it will relearn on it's own, but I doubt that's the problem. "Idle learn" is idle speed related.
    Additive question answered in your other thread.
  9. #8
    Sep 2010
    East Boston MA.
    28
    26,325
    I took "runs like crap" as lopes or sputters from low idle. My mothers '90 Seville did it once after reconnecting the battery.
    If it was running fine before the tire change, I don't see what could have gone wrong.
    padgett1963 and padgett1963 like this.
  10. #9
    68
    81,723
    I didn't pick up on that MC. If that's all that was done, then ignore it and it'll probably go away. Take two aspirin and call us in the morning if it doesn't get better.
  11. #10
    Sep 2012
    Adams WI
    53
    28
    I don't mean to sound stupid.but it never done this untill I unhooked th battery.always well maintained and like I said.it still runs great.now I found the compressor to do again I just un hook that right?
  12. #11
    Sep 2010
    East Boston MA.
    28
    26,325
    You don't have to unhook anything, the compressor is disabled when the ignition is off.
  13. #12
    Sep 2012
    Adams WI
    53
    28
    Whats. MC?
  14. #13
    Sep 2010
    East Boston MA.
    28
    26,325
    Me, my username.
  15. #14
    68
    81,723
    In all honesty, I can't recall my '92 ever doing that after a battery disconnect. Then again, that was a long time ago.
  16. #15
    Sep 2012
    Adams WI
    53
    28
    Ok..went out to just check.jacked it up and the compressor kicked on..everybody else ive talked to tells me it has to be disconnected and no...it doesn't have a leak
  17. Remove Advertisements
