frontend shimmy
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, frontend shimmy in Past Cadillac Vehicle Discussion; Can someone tell me what would make my 2003 deville shimmy violently when braking at high speeds. I'm not a ...
    JimmyPat is offline Cadillac Owners Member
    Automobile(s): 03 deville base
    Apr 2012
    64
    4
    frontend shimmy
    Can someone tell me what would make my 2003 deville shimmy violently when braking at high speeds. I'm not a mechanic but i think it must be the rotors. I had then replaced 7 months ago probably 6000 miles. Thanks, JimmyPat
    Italia deville's Avatar
    Italia deville is offline Cadillac Owners Fanatic
    Automobile(s): 1998 deville
    Feb 2013
    Myrtle beach
    28
    160
    Re: frontend shimmy
    Maybe sway bar links
    Sep 2003
    Metro ATL
    4,854
    Re: frontend shimmy
    Quote Originally Posted by JimmyPat View Post
    The single most common cause of shudder/shaking/shimmy when braking from high speeds is the (impossible to see) uneven distribution of brake pad material on the surfaces of the rotors. That uneven distribution can result from many different driving patterns but the easiest one to visualize is braking for an Interstate exit ramp and having to clamp the pads to rotors at the end of the ramp waiting for a traffic signal to cycle green for you. The (hot) pads are in firm contact with the (hot) rotors as the now stationary rotors cool down. Result equals pad material transfer to the rotors as you wait for the green light with your foot on the brake pedal.
    An easy (free) method of eliminating the uneven pad material distribution is to build up some serious heat in the pads and rotors without coming to a complete stop during the process.
    Try this as a test and possible/probable solution; on a lightly travelled (safe) stretch of rural highway, make a hard brake application from ~~45 MPH down to barely moving without invoking ABS or coming to complete stop. Repeat 10 times as quickly as possible. After the 6th or 7th hard brake application, your pads and rotors 'should be' hot enough to generate smoke and the aroma of hot brake pads. That is a GOOD sign.
    Without coming to a complete stop, drive the car for several minutes to allow some cooling. Then park the car for 30 to 60 minutes and do not set the Park brake.
    I shudder to think about how many rotors have been replaced when replacement was totally unnecessary.
  5. #4
    68
    81,751
    Re: frontend shimmy
    Assuming you are talking about "brake judder" or vibration", here's the explanation. A true "shimmy" is something else.
    http://www.stoptech.com/technical-su...nd-other-myths
    If Jim's procedure doesn't help, having the rotors trued with a light skim cut will do the trick (assuming that's what the problem is).
  6. Remove Advertisements
