Love the power of my 4.6
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Love the power of my 4.6 in Past Cadillac Vehicle Discussion; Never knew how much power these north stars have until first WOT...
    Italia deville's Avatar
    Italia deville is offline Cadillac Owners Fanatic
    Automobile(s): 1998 deville
    Feb 2013
    Myrtle beach
    28
    160
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,273
    Re: Love the power of my 4.6
    Wait 'till you drive one with the 3.71 final drive. Your car has the 3.11 economy final drive for highway cruising.
    (These engines like to be "exercised" once in a while.) Read the entire Cadillac Technical Archive way up ^^^ in the black bar.
    Feb 2013
    Myrtle beach
    28
    160
    O yeah I'm going to WOT once a month cause I normally baby my deville down ocean blvd back and forth to work
    AElayyat's Avatar
    AElayyat is offline Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    For what they are & how big the car is, yeah they got some balls!
    When I am entering the freeway before I know it I'm already @ 85 passing up on going traffic!
    Enjoy the Caddy!
    Mr.Pink is offline Cadillac Owners Member
    Automobile(s): 2001 Deville, 4.6L
    Mar 2013
    Jeff City, MO
    40
    8
    Ive been babying mine every since i got it. I just thought that that how you roll in a caddy, slow and low! ha!! Did my first WOT today on the way to work and... Wow! N*'s are awesome! and apparently, from researching on this forum, they need a little abuse now and then. They were designed for it and it helps clean the crud out of the fuel/exhaust systems. so Ive decided to add WOTs in to the schedule. Im stoked to know Ive got a justifed reason now to open her up every once in awhile!!! - PINK
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It doesn't clean the fuel or exhaust systems, it removes carbon buildup from the combustion chambers, and from the piston ring grooves.
    scanssystems's Avatar
    scanssystems is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac DHS; Galaxy Silver 252k
    Mar 2012
    New Jersey
    701
    In my philosophy: more revs - more torque - big load on engine head studs threads - closer head gasket problem. So I never put more than 2000. Maximum 2.500 on highway. I'm babysitting my high mileage girl.
    Sep 2010
    East Boston MA.
    29
    26,325
    WOT/high RPM has absolutely nothing to do with pulled head bolt threads or HGs.
    68
    82,082
    The engine was designed and built to be and be used as a high performance engine.
    Feb 2006
    56,273
    Quote Originally Posted by scanssystems View Post
    Wrong philosophy.
    You are prematurely aging the engine, building up carbon in the combustion chambers, slowly clogging the cat from too little hot gas flow, and possibly prematurely fouling the spark plug tips from too little combustion heat.
    2,500 highway rpm is ~90 mph in your car - Jersey Turnpike ?
    Nobody is advocating running the car hard every day - go back and read the Cadillac Technical Archive article "Occasional full throttle operation is good for your engine". The operative word there is "occasional".
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    if you have a HG problem a WOT exercise won't make it worse ... it will just bring the issue out from the shadows
    Mar 2012
    New Jersey
    701
    Well, I confused WOT with full thortle. I'm sorry for that.
    But when I said 2500 I meant startup on highway in order to be in a flow while car changing gears up. Not constant drive.
    Here on turnpike we have 65.. so 80 you can drive freely. Just make sure you are in a flow.
    Sep 2007
    Wilmington, NC
    13,986
    WOT = wide open throttle aka full throttle
    they're the same
  16. #14
    Feb 2013
    Myrtle beach
    28
    160
    Gotta hit 6,200 rpm every once in a while clean that baby out
  17. #15
    Sep 2007
    Wilmington, NC
    13,986
    that doesn't clean anything out - the cleaning happens as the engine coasts down while engine braking from the higher RPMs
    the purpose of the WOT procedure is to wind the RPMs up so that you can coast back down
    the getting up towards redline isn't as important as the coasting down
    that's why you keep the stick in second gear (or 1st if you're going to be at lower speeds)
    if you keep it in D then the second you let off the gas it will shift up to 4/OD and the engine braking that you are trying to achieve will not happen
  18. Remove Advertisements
