Diagnostic code help...2002 Deville DHS
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Diagnostic code help...2002 Deville DHS in Past Cadillac Vehicle Discussion; Here are the codes that were in the system from last week when I pulled them. Also, the radio was ...
    Sean Ab's Avatar
    Sean Ab is offline Cadillac Owners Member
    Automobile(s): 2002 Deville DHS
    Mar 2013
    Central Minnesota
    10
    Here are the codes that were in the system from last week when I pulled them. Also, the radio was intermittent prior to the battery dying and being replaced. Shortly after I put in the new battery is when the radio went completely out.
    Codes
    ABS
    C1282 HISTORY - YAW RATE SENSOR BIAS CIRCUIT MALFUNCTION
    C1287 HISTORY - STEERING SENSOR RATE MALFUNCTION
    C1295 HISTORY - BRAKE LAMP SWITCH CIRCUIT OPEN
    AMP
    U1000 CURRENT - CLASS 2 COMMUNICATIONS MALFUNCTION
    U1128 HISTORY - LOSS OF COMMUNICATIONS WITH IRC
    IPC
    U1016 HISTORY - LOSS OF COMMUNICATIONS WITH PCM
    U1151 HISTORY - LOSS OF SERIAL COMMUNICATIONS FOR CLASS 2 DEVICES
    B1004 HISTORY - KEEP ALIVE MEMORY
    IPM
    B0429 CURRENT - TEMPERATURE CONTROL #3 REAR CIRCUIT RANGE/PERFORMANCE
    I cleared them last week and the only ones that keep appearing are all of the ABS codes less YAW, the U1000 AMP code, the U1000 IPC code, and the B0429 IPM code. (this only appears when the heater is on. I have cleared it and ran diagnostics with the heater off and there is no code.) I also keep getting svc stability system and traction control lights.
    Other possible symptoms that I have observed.
    -The lights on the DIC don't work on either side. I assume that they are supposed to work because finding them at night is a pain.
    -The radio button lights work except for the preset buttons. There is no clock or display information
    -The light in the Driver Door lock switch doesn't work along with the 1, and 2 buttons on the driver memory settings buttons. (I assume that these are bad bulbs, but maybe not?? How are the bulbs/LED replaced?)
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    Re: Diagnostic code help...2002 Deville DHS
    History codes will eventually disappear on their own. The B 0429 tells you that the diverter door/actuator for the airflow to the rear console vent system is messed up.
    U codes come and go like clouds - voltage hiccups, data flow hiccups, iffy electrical connectors.
    The various button lights - you're in the switch replacement business or the switch disassembly/soldering business............. most of them are "grain of wheat" bulbs - 2006 technology for automotive LED use wasn't around yet ....................
    Sean Ab's Avatar
    Mar 2013
    Central Minnesota
    10
    So do I replace the head unit or is it all in the wiring?
    Sean Ab's Avatar
    Mar 2013
    Central Minnesota
    10
    Quote Originally Posted by Submariner409 View Post
    So do I replace the head unit or dig into the wiring?
    69
    82,163
  8. Remove Advertisements
