99 Deville having starting problems
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 99 Deville having starting problems in Past Cadillac Vehicle Discussion; Hello everyone so I have a 99 deville and sometimes it starts up just fine and other times I have ...
    mrluigi1120 is offline Cadillac Owners Member
    Automobile(s): 99 cadillac deville
    Jan 2013
    san diego
    13
    Hello everyone so I have a 99 deville and sometimes it starts up just fine and other times I have to crank it at least three times and give it some gas when I turn the key I can hear the gas pump working so I don't know if all I need is a starter anyone have any suggestions
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    Does it attempt to start(cranks) or does nothing happen when you turn the key?
    If it is cranking then starter is fine.
    69
    82,382
    Re: 99 Deville having starting problems
    Clean the TB and check for a leaky FPR if the hard starts are when it's hot.
    Jan 2013
    san diego
    13
    What's a fpr
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    Use the "Acronyms" sticky post just above this thread. (Stickies at the top of every forum page are your friend, as well as the entire Cadillac Technical Archive way up ^^^ in the top black banner.)
    The FPR is located on the right rear end of the fuel rail, held into the rail fitting by a hairpin retainer clip. It maintains running fuel pressure at 41 - 47 psi. Remove the engine beauty cover. There is a vacuum line from the FPR to the throttlebody - manifold vacuum side. Carefully pull the vacuum line connector off the FPR nipple - any raw gas there indicates a failed FPR inner diaphragm. If the vacuum line/connectors are cracked/broken, the whole line can be replaced with a proper sized length of vacuum hose from the Help! racks at a large parts store or NAPA.
    Google "cadillac forums 1999 deville fuel pressure regulator".
    69
    82,382
    FPR. Red arrow is vacuum. Yellow is fuel.
    Jan 2013
    san diego
    13
    Awesome I will be working in my car tomorrow so ill check it out. But it usually starts hard when its hot and I got to give it a few pumps I don't if this makes any difference once again thanks for all the help
    69
    82,382
    That pretty much put the nail in the FPR's coffin.
  11. Remove Advertisements
