2004 DHS Window Motor Literally Broke Apart
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2004 DHS Window Motor Literally Broke Apart in Past Cadillac Vehicle Discussion; Driver's side front window has become increasingly slow over time. It eventually stopped working completely and would make a grinding ...
    Lance Allison is offline Cadillac Owners Member
    Automobile(s): 1993 Sedan Deville
    Oct 2003
    Central Illinois
    20
    Driver's side front window has become increasingly slow over time. It eventually stopped working completely and would make a grinding noise. There is a picture of what the motor looked like once I removed it from the door.
    Has anyone seen this before?
    Thanks!
    68
    82,081
    Re: 2004 DHS Window Motor Literally Broke Apart
    WOW! That puppy was really stressed to break like that. Might take a good close look at everything else to see if anything is binding.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Was reading that silicone lube works great in the window tracks.
    There are some youtube videos about cleang and lubing window tracks.
    The slicone lube is supposed to be the prefered lube for most all the door parts
    Oct 2003
    Central Illinois
    20
    Hmm...I posted a followup to my initial post, but it's not there. Anyway, I did clean the big horizontal and large vertical channels with Sil-Glyde (Napa's silicone grease), then sprayed the big spring looking thing in the middle of the regulator with AeroKroil.
    I'm keeping my fingers crossed, but so far it's the fastest window in the car. Time will tell ;-)
    Thanks guys.
    Oct 2003
    Central Illinois
    20
    Well I'm probably jinxing myself but so far so good. Its surprising to see how much the workings of the window motor move....so far so good.
    Why would a salvage yard say the window mechanicals are integral to the door. One local place told me i'd have to buy the whole door....impossible to remove the window motor and regulator. Are you kidding me
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,653
    Because they want more $$$ from you, no other reason.
    Oct 2003
    Central Illinois
    20
    Well it's been 3 weeks since I swapped window motors. Working flawlessly. Thanks for your input.
  10. Remove Advertisements
