P 0506 again - low idle speed
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, P 0506 again - low idle speed in Past Cadillac Vehicle Discussion; 2003 Deville w/ 125K miles. Every couple of months it will not idle stalls out . Can't be TB cleaning ...
    bobstanster's Avatar
    bobstanster is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Apr 2012
    165
    2003 Deville w/ 125K miles. Every couple of months it will not idle stalls out . Can't be TB cleaning or it would be a full time problem , same with vacuum leak , the problem would be constant not intermittent .
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    Re: P0506 again!!!!!
    P 0506 - http://myweb.accessus.net/~090/dtcobd2.html
    Thanks for the definition (I changed your thread title to better reflect the problem)
    "Idle speed low" can be several things, not simply the IAC. Vacuum leak problems normally cause fast idle, IAC passage problems cause low idle. TPS (Throttle Position Sensor) can cause idle faults. Excess engine loads (aftermarket batteries and alternators) can cause low idle problems. Air filter new within 12,000 miles ?
    Apr 2012
    165
    Problem was pretty bad then we had very unusually warm weather and the problem went away . What gives ?
    69
    82,162
    Re: P 0506 again - low idle speed
    Eliminate the free stuff first and clean the TB.
  7. Remove Advertisements
