new 97 Deville preventative maintenance
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, new 97 Deville preventative maintenance in Past Cadillac Vehicle Discussion; Hi guys, im new to the forum and recently purchased a 1997 Cadillac Deville (base model) with 104,000 miles that ...
    cadillacflipper is offline Cadillac Owners Fanatic
    Mar 2013
    103
    Hi guys, im new to the forum and recently purchased a 1997 Cadillac Deville (base model) with 104,000 miles that seem to have been pretty well taken care of, runs and drives smooth and quit.... I was looking for some insight on what would be some good steps to take to make sure everything is up to date on maintenance and preventative maintenance since i dont really know when the last time any type of service has been done to the vehicle
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,751
    Re: new 97 deville
    Spark plugs and wires are due, based on Cadillac's reccomendations. Use AC Delco stuff only, Northstars are picky. Change the coolant yesterday, and DO NOT use any of the sealant tab additives. They are worthless. Other than that, replace and service as needed, AFAIK.
    btw, and let's see the DeVille!
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    Re: new 97 deville
    Welcome, i have a 97 base deville also,,,basically just maintain all fluids and do change all plugs, put in double platinum ac/delco, do not gap them, they are plug and play, change the wires and antifreeze if you want....orange or green, does not matter on ours...you should be good to go
    Mar 2013
    103
    Appreciate the advice fellas, i was already on top of the oil change and radiator flush but was a little hesitant on the plugs and wires because it was running so smooth and quite..... And cadillacluke24 I'll get sum pics up for ya
    68
    82,072
    Re: new 97 deville preventative maintenance
    I edited your title. "New '97 Deville" is not very descriptive.
    Mar 2013
    103
    Ok, thanx, whatever will get me more info
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Transmission fluid and filter?
    Lift a tire off the ground - pull - push - shake the tire to feel for any play.
    Pull the tire off and inspect everything carefully.
    Mar 2013
    103
    I've checkd a couple spots that are only willing to drain and refill the transmission fluid but not replace the filter...... And on the tires, remove the front? Rear? Or all 4?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,251
    The transmission filter is only serviced at total overhaul. There are screens that can be cleaned with a transmission pan drop. If you do a flud change, you might as well go to the new (2006) DEXRON-VI synthetic fluid - 100% backwards-compatible with the obsolete DEXRON-III.
    The tire thing - with a wheel/tire jacked up, grab the tire at 12 and 6 o'clock. Attempt to rock the tire in and out - any play is hub/bearing assembly. For the front wheels, grab the tire at 9 and 3 o'clock and rock it as if to turn the steering wheel. Any play is inner or outer tie rod ends.
    With the car up on a 4-point hoist, carefully inspect the sway bar bushings and the lower suspension arm bushings. Common wear points in ANY older car.
    Mar 2013
    103
    So a simple fluid swap would be just fine for the moment if im not having any trans problems?
    68
    82,072
    Yes.
    Mar 2013
    103
    Ok cool, i guess dat will be next
    Mar 2013
    103
  16. #14
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Nice. ???But explain the third picture.
    Never mind, found them online. I'm buying 4, those are awesome!
  17. #15
    Mar 2013
    103
    Yeah they are attention grabbers..... Im going to be doing the back doors soon
  18. Remove Advertisements
