92 Deville Intermittent Cold Start Problem
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 92 Deville Intermittent Cold Start Problem in Past Cadillac Vehicle Discussion; Codes E30-ISC RPM out of range E31-Shorted MAP Sensor Signal E53-Distributor Signal Interrupt Car has been running great since I ...
    209 Big Bodies is offline Cadillac Owners Member
    Automobile(s): 1992 Sedan Deville (186,000), 1996 Impala SS DCM (135,000)
    Feb 2013
    Stockton, CA
    31
    14
    Codes
    Car has been running great since I got it over a month and 1000 miles ago. It has always started up immediately but over the last week I have needed to give it gas while starting it- revving it a little. Once started it runs fine (slight rough idle). I was thinking fuel pump at first and switched the old gas cap because I didn't notice the "whoosh" when removing cap to refuel. Helped a little but I still get the starting problem almost every cold start. Checked connections, FPR, and everything seems fine. I will not get a chance to really start messing with it till this weekend when I head home (FSM, tools,garage) but I was hoping to get an idea of what to look for. Will try ISC relearn and probably replace distributor since I have a rebuilt one.
    Any ideas or similar circumstances?
    Here is a little more history of the car if interested.
    http://www.cadillacforums.com/forums...ew-member.html
    Thank You,
    David
    Feb 2013
    Stockton, CA
    31
    14
    Re: 92 Deville Intermittent Cold Start Problem
    So now the car will not stay on even when given gas. I can keep it running after I start it as long as I keep my foot on the pedal but as soon as I let go it now dies. I wanted to get it to drive an hour away so that I can have a garage to work on it but I need to keep it running. I don't think the MAP sensor, ISC, and distributor all gave out at the same time so could one thing cause the others?
    Any ideas so I can at least get it started and running?
    68
    82,064
    If it will not idle on it's own, but you can keep it running with the accelerator, it has to be a failed ISC motor. Unplug it and run the plunger out enough to keep it idling. That should enable you to get it to a garage. Just be sure to tell them what you did.
    Feb 2013
    Stockton, CA
    31
    14
    Ok that sounds good I appreciate it. So if the MAP sensor shorted does that mean it is now definitely bad too and should be replaced along with the ISC?
    Thanks
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    A shorted MAP sensor will make it run pretty bad and they are easy to change. I don't know if a simple vacuum leak will cause that code or not but would be worth checking for anyway.
    Feb 2013
    Stockton, CA
    31
    14
    Replaced the ISC motor and the car is starting and running great again. Did not touch the distributor or map sensor. I am curious if anyone knows the part number for the pigtail/wiring harness that connects to the ISC? It works but some of the plastic broke off of the clip as well as one of the 4 prongs that goes into the ISC.
    Thanks again for the help.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Doubt it is available unless you buy at a dealer as a repair end and those are major overpriced. You might try a salvage yard, pick your part or something like that.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    There are repair pigtails available:
    http://www.theautopartsshop.com/auto...connector.html
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    trev321 is offline Cadillac Owners Member
    Jul 2014
    1
    im having same problem... have u found problem yet ??? thanks
    68
    82,064
    Don't expect a response from this 16 month old thread. The OP hasn't been back here since 08-14-13.
  14. Remove Advertisements
