1998 Concours codes
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1998 Concours codes in Past Cadillac Vehicle Discussion; Hello to all and sorry for the late return. I pulled the following codes and need to know exactly what ...
    dadscours is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Dec 2012
    Chicago
    59
    37
    1998 Concours codes
    Hello to all and sorry for the late return. I pulled the following codes and need to know exactly what they mean so please feel free to chime in.
    1. P0174 fuel trim system lean bank 2
    2. P0171 fuel trim system lean bank 1
    3. P040 Catalyst system low efficiency bank 1
    4. P1376 IC Module Ignition Ground Circuit malfunction and,
    5. P0300 Engine misfire detected
    Where should I start?
    Thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,870
    Re: 1998 concours codes
    Remove the engine cover and begin checking for vacuum leaks - the P 0171 / 0174 are lean mixture codes - usually an air/vacuum leak - anywhere from the throttlebody to intake manifold to overpressure valve to various vacuum lines.
    P 1376 might be the ground cable at the ICM - the coils are mounted on it. Spark plug wires go to specific coil terminals - mark them.
    The catalyst and miss code(s) may be due to the above.
    Dec 2012
    Chicago
    59
    37
    Thank you Submariner.
    Dec 2012
    Chicago
    59
    37
    Hello to all, Took caddy in for a professional diagnostic, they found the following vacume leak, INTAKE PLENUM DOOR.
    It also might need the catalytic converter replaced but recommended the plenum door replaced first.
    Their estimate is $391.00, How difficult of a job is this?
    68
    81,902
    "Intake plenum door"? Does that mean the manifold over pressurization valve? If so, it's not terribly difficult (depending on your skill level). You'll need to remove the manifold aka intake plenum.
    Dec 2012
    Chicago
    59
    37
    This is exactly what the mechanic showed me. I have also order a set of service manuals and will give it a try.
    Thanks for the pics and assistance.
    68
    81,902
    It's possible that it might just need to have the seal and seat cleaned. Nothing to loose by trying.
    Dec 2012
    Chicago
    59
    37
    Would a damp cloth be sufficient or will I need a special type of cleaner?
    Thanks Ranger
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,363
    Quote Originally Posted by dadscours View Post
    Thanks Ranger
    spray it down with THROTTLE BODY CLEANER -
    Dec 2012
    Chicago
    59
    37
    Thanks much. This will be my tomorrow project.
  13. Remove Advertisements
