High Mileage oil ? - Page 2
Results 16 to 30 of 38
Like Tree7Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, High Mileage oil ? in Past Cadillac Vehicle Discussion; Originally Posted by donwon I know it cost me a couple of mpg in my 4.9. I have a friend ...
  1. #16
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by donwon
    I have a friend who talked me into using 5-w-15 Valvoeine and my olm came on about 3500 miles instead of the 5000+ miles with 15-w-40 Rotilla that I normally use.
    Yea I noticed the OLM drops faster
    I realized when I changed my oil that it was obviously to soon... That and the OLM dropped to 99% the same day I drove after my oil change
    So when the OLM says change oil it's really time to reset it and go another 3k
    Also
    If its costing a few MPG I really dnt see it right now as my avg mpg mostly climbs now unlike it did before I changed my FPR. So I'm good til I see that mpg drop.
  2. #17
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,191
    Re: high mileage oil
    Quote Originally Posted by SUPER LAC DEVILLE View Post
    Ummm, NO ! You could change your oil/filter, reset the OLM, start the car and let it idle for 3 hours and the OLM would drop. The OLM drops much faster in town than on the highway - open road cruising is easy on oil, town driving is murder, and the OLM tells you that.
    The OLM in each of our cars is set to calculate oil life for the recommended oil installed in the engine at the time of manufacture - the OLM cannot, will not, won't compensate for you using Mother's Oil Soap or Goose Grease - it will decrement based on the driving conditions, not the type of oil in the engine.
    Use the recommended oil for your engine, use the OLM, and don't try to outguess the car. Drive it.
    BTW - Owner's manuals specifically caution against running oils like 15W-40 in your engine. It's in black and white.
  3. #18
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by Submariner409
    Well if oil has changed in quality over time than the OLM can't won't calculate that either
    But I do retract some of my statement bc I forgot I topped off a few times so the oil may Appear fine at oil changes too
    But wasn't it said that 7k miles was ok for oil change times too???!
  5. #19
    Feb 2006
    56,191
    7,000 miles, 3,000 miles, 10,000 miles - all OK. Depends on your driving conditions and the average weather.
    Lots of cold city driving, short hops, commute less than 15 miles - the OLM will tell you to change the oil/filter at 3,000 - 4,000 miles.
    Mostly suburban driving, warmer weather, long commute - every 5,000 - 7,500.
    Highway road runner - NY to FL, FL to TX - every 7,500 - 10,000 miles.
    In ANY event, at least once a year, mileage be damned.......... and in each case, the OLM will agree pretty close.
    ................ and this is an OLD gearhead trick: If you can, change the oil/filter immediately after a long road run. All the nasties are suspended in the oil (instead of lying in the oil pan) and contaminants will drain with the oil.
  6. #20
    Aug 2012
    Tampa Florida
    38
    854
    So I should change it HOT???
    Bc I do that... Change it when it's hot.
  7. #21
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes.
  8. #22
    Tonyny's Avatar
    Tonyny is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Dec 2003
    Clermont, Florida
    62
    143
    [/COLOR]Who told you that was high mileage for your 2003 DTS?----------The oil container....that's why I came here for advice.
  9. #23
    Feb 2006
    56,191
    Don't believe all the marketing hype you read. Posts #2 and #3.
    (Sorry that SUPER LAC DEVILLE hijacked your thread.)
  10. #24
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    yeah the OLM doesn't know what kind of oil your using or what weight... it assumes you use what they tell you to use (what it has been programmed for)
    what the OLM does know is how many combustion events your car has had since the last time the OLM was reset (counts RPM basically)
    and it knows what the temperature of your oil/engine is (colder oil degrades faster)
    plug those two variable inputs into their patented, researched, and proven formula and display it as a percentage
    boom
    OLM
    jounier11 and jounier11 like this.
  11. #25
    Aug 2012
    Tampa Florida
    38
    854
    I did?
    Oops, sorry
    Quote Originally Posted by Tonyny
    Ahhh, good thing u popped in CF for the info
    Sorry I hijacked your thread as Sub said but I like to get info too!!!
  12. #26
    Sep 2007
    Wilmington, NC
    13,986
    Re: High Mileage oil ?
    https://wiki.archlinux.org/index.php...read_Hijacking
    Thread hijacking is the process of replying to an existing thread with a different topic. This is generally discouraged. It is better to start a new thread if you have a problem that is related to an existing posted issue but clearly different. Posts that hijack a serious thread with off-topic discussion are also tolerated but generally discouraged.
    this instance of thread hijacking is pretty mild since the topic wasn't totally changed ... at least you kept to oil related discussion
    going off the rails to other topics would be a quintessential threadjack
  13. #27
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by RippyPartsDept
    Like changing the topic to batteries or vehicle weight, right?
    I'm trying to see where I got off the oil topic?
  14. #28
    Sep 2010
    East Boston MA.
    29
    26,325
    It went from the original question of high mileage oil, to viscosity, to fuel mileage, to the OLM...... to what constitutes as a hijack.
    Welcome to Cadillac Forums.
  15. #29
    Feb 2006
    56,191
    Don't beat a dead horse - The OP chimed in and got his requested info - even though the thread wandered - color us all guilty.
  16. #30
    Aug 2012
    Tampa Florida
    38
    854
    Ok thanks for the correction
    Ill try not to thread jack
    Mmmmm, OIL, num num num.
  17. Remove Advertisements
