Results 1 to 4 of 4
Thread: Oil in Overflow
    Masseylakeboy is offline Cadillac Owners Member
    Automobile(s): 91 Fleetwood Base
    Mar 2013
    36
    1
    Oil in Overflow
    I have a 91 Fleetwood. I recently found oil in the radiator overflow. The oil and trans fluid looks normal. I have hoses coming off the radiator that have oil all over them. I am also getting a service A/C light when I turn the A/C on. Could the air not working cause this leak into the overflow or is it the radiator?
    rodnok01's Avatar
    Feb 2012
    NC
    6,701
    Re: Oil in Overflow
    A/C has nothing to do with it, they are 2 completely different systems.
    aeronca36606 is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Coupe Deville 4.1 V8 & 4.3 V6 Deisel & 1970 Eldorado
    Sep 2005
    East Tennessee
    773
    Re: Oil in Overflow
    Suspect oil cooler or trans cooler in radiator.
  5. #4
    69
    82,272
    Re: Oil in Overflow
    By the way, if oil (or trans fluid) is leaking into the coolant, coolant will leak into the crankcase (or trans) after shutdown. The engine will tolerate oil (or trans fluid) in the coolant, but the engine (or trans) will not tolerate coolant in the oil (or trans fluid) for very long.
  • You may not post replies
