interior instuments lights
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, interior instuments lights in Past Cadillac Vehicle Discussion; Several lights on my climate contol module are out, so at night i tend to hit the wrong ones... anyways ...
    White_DTS is offline Cadillac Owners Member
    Automobile(s): DTS
    Dec 2012
    29
    14
    Several lights on my climate contol module are out, so at night i tend to hit the wrong ones... anyways is this fix as easy just popping the button off and replacing the bulb?
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    The fix is very easy. Look for a T5 neo wedge bulb of ebay or something. I cant remember hiw many are in there but I belive there are 5 including the temp dial. Then all you have to do is take out the module, use a small flat screw driver and pop the 4 clips across the top to separate the to half's and the lights will be right there, just use the screw driver to twist them out.
    Automobile(s): DTS
    Dec 2012
    29
    14
    Re: interior instuments lights
    thanks man
