1999 Deville Radio gets power but puts out no sound (after amp & sub installation)
Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By caddev99
  • 1 Post By SUPER LAC DEVILLE
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1999 Deville Radio gets power but puts out no sound (after amp & sub installation) in Past Cadillac Vehicle Discussion; Just went and had a 2000W Legacy Predator amp hooked up to two 12" Volfenhag 1000W speakers. Still got the ...
    caddev99 is offline Cadillac Owners Member
    Automobile(s): Deville 1999
    Mar 2013
    3
    Just went and had a 2000W Legacy Predator amp hooked up to two 12" Volfenhag 1000W speakers. Still got the factory radio and had it installed professionally with the RCA converter kit. It worked fine when I left the shop, but the next day when I woke up and went to go to college the radio worked showed the time, stations, etc. but had absolutely no sound. I've check and replaced the fuses involved with the radio and factory amp but still nothing. I tinkered with it a bit the next day and took off the positive from my battery to hope to reset the system and get it going again, it worked, until I turned off the car again and the next time I got in I was back at square 1. There's not many people able to come into the shop and I really need to figure it out so I know if it can cause worse problems or not please help!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,480
    Re: 1999 Deville Radio gets power but puts out no sound (after amp & sub installation
    why not take it back to the original installer -
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    sounds like the amp may have fried the HU sound board
    That much power the wrong way in the slightest can fry transistors, resistors etc
    These HU's jus dnt like to be tampered with... even on the back end
    System upgrades, from what ive discovered, usually require power and ground wire upgrades to zero gauge so the power can "flow" with less resistance... the smaller the wire the more resistance... the more likely those wires will burn up. That much power is Alien to your Deville so even if u fix the problem your having now, youre very likely to experience more problems down the road if you dont upgrade your wires properly.
    If u got a "Professional" shop to do the Install... then you might want to ask them if they did "The Big Three" and what Guage wires they used to Install your New system
    The Devilles, older devilles jus werent designed for these type of systems so if it wasnt done with that consideration it can fry your HU and possibly other things that are far more expensive
    Ive said this before and ill continue to convey this... First thing I learned about the late 90s Deville is every system is Married to another system... and the Radio certainly is NOT an Independant system
    you can youtube "the big three" and get the general idea for serious aftermarket upgrades
    jus my 2cents tho
    Quote Originally Posted by basscatt View Post
    pompste likes this.
    Mar 2013
    3
    I really appreciate the feedback and I am sorry for the late response, been real busy with the car difficulties and college work. They installed 4 gauge power wire and ran tag lines from the rear speakers to the rca converter box and into the amp. After reading your response I looked up the video an realized that my Cadillac was not designed to handle little wattage, let alone 2000W, AND no capacitor. I really set myself up for disaster here, I figured that the installer would have let me know anything like that before he installed it but I guess I give people the benefit of the doubt too much. I learned my lesson though, don't screw with a Cadillac's electrical system.
    So I went to get in the car today and the battery was dead, completely drained, and I don't have a clue why. The relay in the back of the rear seats was clicking like crazy, even without the keys in, I pulled the COMFORT fuse out and it stopped. I put the fuse back in because it was in almost perfect shape I am going to switch it out just to be sure. Turned out that the battery was shot and I went and bought a new one it's back to the way it was also, I unplugged the speakers and the amp and took them out. Kind of lost now, I don't know if the battery was shot when it was initially installed or if it was shorted out over time. I really played with fire putting that system in without the proper research.
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by caddev99
    The older Devilles like ours normally need another battery and a fairly large capacitor... I always go with 0 Guage for the main positive and negative wires
    I've seen a few that have done fine without the extra battery and capacitor tho
    Your main battery and alternator should absolutely be 0 gauge wires when dealing with that much power, 4 guage is jus not sufficient for systems over 1000w
    For example, my speaker upgrade alone (5.25 & 6x9s) draw so much more power that my interior lights and head lights dim with the beat of the music
    Months ago I hooked up 2 JL 10w3v3's to a simple 500w 1channel amp and it sucked the battery down to 11v in a matter of a min or two... Disconnected it thereafter and RESEARCHED and EXAMINED my audio electrical system... Traced it back to the alternator and battery and concluded that's where to start UPGRADING
    The small space to work with under the hood has deterred my efforts since but I've almost got all the Necessary equip to get started... Once I do this its not something ima wanna REDO for any reason so first time needs to be right.
    Your installers should know about the Deville... Real installers have atleast 3 or 4 on average in their portfolio
    That's always my first question when talking with a "PRO INSTALLER"... How many Cadillacs or Devilles have you done... If they say none or one I don't even continue the convo... They're expertise is limited and if I know more than them about this install, they're wasting my time and eatn my money
    I would suggest u research this for a couple months atleast... Look at what others have done and read what others have experienced... YouTube helps a lil but not a lot with the Deville.
    IT CAN BE DONE... AND DONE RIGHT, so dnt give up. Jus know how to spend your money and who to give it to when u do decide to proceed with the install
    Jus a quick note
    A basic upgrade in stock speakers will give u some pretty good sound. I put in Kickers (5.25 & 6x9s) and they're pretty loud even without the wattage they require
    Good luck with your venture tho!
    Mar 2013
    3
    So I'm back, I found out that the radio and the door chimes work when the battery is low on power (Low enough to where the car doesn't have enough power to start). When I do not have the key in the radio works perfectly but when I have the key in and have the key turned to power up the car the radio puts out a hissing noise at higher volumes. There is also a drain on the car when it is running and driving around.
  9. Remove Advertisements
