99 Deville Leveling System.....
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 99 Deville Leveling System..... in Past Cadillac Vehicle Discussion; Hi Ya'll, Just picked up a 99 Deville, 70k miles. I'm having an issue with the rear leveling system. It's ...
    lisnjay is offline Cadillac Owners Member
    Automobile(s): 99 DeVille
    May 2006
    Northern Illinois
    35
    Hi Ya'll,
    Just picked up a 99 Deville, 70k miles. I'm having an issue with the rear leveling system. It's not too low like all the other posts I've seen. It's WAY TOO HIGH! The car looks like a cat in heat with it's rear end in the air.
    I've checked the fuses, codes and even tried to adjust the sensor. Anything I'm missing besides a new pump?
    Can someone give me a measurement for the rear end to go off of?
    Thanks everyone!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    Re: 99 Deville Leveling System.....
    Quote Originally Posted by lisnjay View Post
    Hi Ya'll,
    Thanks everyone!
    the Electronic Level Control system is pretty simple -
    it consists of rear shocks that use built in air bladders
    that are inflated or deflated to maintain the proper ride height
    regardless of weight in the back seat and trunk -
    the level control switch senses the ride height -
    and either signals the compressor to engage to inflate the air bladders -
    or signals the exhaust valve to open - and deflate the air bladders -
    or do neither if the ride height is correct -
    the compressor assembly houses the compressor and exhaust valve -
    to either inflate or deflate the air bladders in the shocks -
    if the level switch isn't signaling the exhaust valve to open -
    the rear will sit high -
    likewise - if the exhaust valve doesn't open -
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,651
    Both my 97 &98 are @ 26" measured top center of wheel opening to the ground. I set mine up from FSM measurements, so they're close anyways. Without measuring: top of tire maybe 1/2" hidden(with driver in car). If you can see all of the tire it's high.
    68
    82,064
    Have you pulled the DTC's? I'd almost bet you'll find C0660 - Level Control Exhaust Valve Circuit Malfunction.
    May 2006
    Northern Illinois
    35
    I have pulled the codes from the dash, but not with a code reader. No suspension codes. No codes as a matter of fact.
    Is there a way to test the switch on the driver's rear tire or do you just replace it?
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    You can adjust it, so yes it can be tested there also.
    May 2006
    Northern Illinois
    35
    I've already adjusted it "down" so I'm assuming that it's the pump. Thanks for your help!
    Well just pulled to see if there were any codes that popped up. No codes, so I guess I will try replacing the switch before the pump.
    Thanks again all!
    May 2006
    Northern Illinois
    35
    Well I'm not going to replace the pump till after I get back from vacation next week. In the mean time, is there any way to temporally "deflate" the system a bit?
    68
    82,064
    Manually operate the switch or unplug the air line from one of the shocks.
  12. Remove Advertisements
