Can I flat tow a 92 DeVille behind my rv?
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Can I flat tow a 92 DeVille behind my rv? in Past Cadillac Vehicle Discussion; Can a 92 Deville be flat towed behind an RV? Maybe with a Lube Pump?...
    ibdilbert is offline Cadillac Owners Member
    Automobile(s): 92 DeVille
    Feb 2013
    39
    23
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,480
    Re: Can I flat tow a 92 DeVille behind my rv?
    Quote Originally Posted by ibdilbert View Post
    you didn't say whether you are going 1 mile or thousands of miles -
    I can think of a lot of reasons why NOT to - but - even if you could -
    you would be better off using a CAR DOLLY - like this -
    you can rent one from U-Haul -
    Feb 2013
    39
    23
    Sorry, thousands of miles for sure. I've been flat towing a Cherokee, it doesn't require any modifications to be flat towed. Buying a car dolly might be my only option, but I hate having that extra peice of hardware to deal with on my camp site.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Now there's a picture of gas burning excess. A big old motor home pulling a cadillac. A motor home with caddy/towbar takes up same space as the caddy on a tow dolly. Maybe u go to a rv park for awhile and prefer to not have to walk around tow dolly when ur using caddy? But, a tow dolly is pretty slick for 1000 mile pulls. U will always be able to sell it when ur done with it.
    The Donald is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville delagance
    Apr 2012
    Colorado
    210
    NO YOU CANT WITHOUT DAMAGE TO THE AUTO TRANSMISSION You must use a car dolly You cannot tow because of inadequit lubrication for the tranny..
    Feb 2013
    39
    23
    "NO YOU CANT WITHOUT DAMAGE TO THE AUTO TRANSMISSION" - Actually that may be an incorrect statement. If my DeVille has nothing more than a standard 4T60-E transaxle, then its very doable with a Remco Lube Pump.
    "Now there's a picture of gas burning excess. A big old motor home pulling a cadillac." Now vision a big old gas guzzeling 1970 Winnebago pulling a Cadillac! Still the Cadillac is lighter than my Cherokee.
    "a tow dolly is pretty slick for 1000 mile pulls" Makes sense to me! And Remco wants almost 1000 dollars for the pump kit, I can buy a dolly for that. I may have to start learning about dollys.
    68
    82,064
    Personally I wouldn't chance it. I'd use the dolly. You should be able to rent one pretty cheap.
    http://www.uhaul.com/Reservations/Eq....aspx?model=TD
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    47
    413
    Get the tow dolly, they're not that hard to use and would be better than a tow-bar because they pivot under the front axle rather than just force it to turn against strait tires. The Lube-pump would be one more piece of hardware on the Cadillac that you don't want to have to deal with, esp if it failed you. KISS. Maintenance on a tow dolly would be trailer lights and wheel bearings, easily serviced. And with a hitch on the car you can transport the dolly without the RV if needed.
    Vernon
    Feb 2013
    39
    23
    You guys have talked me into it, I'm going to do some research on car dollies and purchase one. I've flat towed a lot of vehicles, and never used a dolly, so this is a new experience for me.
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Master Tow makes a good one, owned and used several. Keep it locked up but good, they seem to grow feet and walk off...
    Feb 2013
    39
    23
    Thanks for the info as I've been looking at a new Master Tow new with brakes just shy of $1200. No brakes they are a lot cheaper, but some of the states I travel through require brakes.
    Just in case someone else is looking to tow and doesn't want to go the tow dolly route, the lube pump kit from Remco is LP-BK01-007 and it retails for $950.00.
  14. Remove Advertisements
