no power to drivers side rear door?
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, no power to drivers side rear door? in Past Cadillac Vehicle Discussion; Good day; There is no power to this door. No seat heater, no window, no locks. Can't even opperate L/R ...
    Cadygrl's Avatar
    Cadygrl is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4, 156km, 2000 DTS, Northstar, 160,000K
    Oct 2011
    Winnipeg, Mannitoba, Canada
    40
    137
    Good day;
    There is no power to this door. No seat heater, no window, no locks. Can't even opperate L/R window or locks from drivers door.
    I checked all the fuses under the back seat, all seem ok.
    Where to next?
    Thanks...
    Ken
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    Re: no power to drivers side rear door?
    Quote Originally Posted by Cadygrl View Post
    Good day;
    Where to next?
    Thanks...
    Ken
    double check those fuses under the back seat -
    pay particular attention to #3 and #5 -
    also check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Cadygrl's Avatar
    Oct 2011
    40
    137
    Thanks Basscatt,
    I checked all of them again and they all were hot on both pins. I pulled checked and reinstalled #3 and #5 and nothing in that door works.
    Pulled codes:
    IPC U1000 current; instrument pannel cluster....class 2 comunication failure
    RIM U1000 current; rear integration module....class 2 communication failure
    thanks Ken
    blackonblacklac00's Avatar
    blackonblacklac00 is offline Cadillac Owners Enthusiast
    Automobile(s): PREVIOUS 00DTS,04DTS,04DTS,03CTS,07CTS CURRENT 07STS4 09CTS4
    Oct 2008
    TORONTO CANADA
    522
    Might need another door module BUT once on my 2000 dts I had a similar problem ended up being wires broken in the rubber boot in the door jam.
    I would first try removing the door panel and unplug and plug all wires to the module, if nothing then I would CAREFULLY slice open the rubber boot covering all the wires in the door jam and see if any are broken. Over time wires become brittle and break in cold weather from the door opening and closing.
    If all is intact and still no luck, I would start looking in scrap yards for a rear door module or ebay
    Found one for $40
    http://item.mobileweb.ebay.com/viewi...id=44537683514
    White Lightning is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Deville DTS
    Jan 2012
    MA
    78
    I second that on the checking the door jamb, should be a large red wire and black wire for power and ground.
    rodnok01's Avatar
    Feb 2012
    NC
    6,699
    I agree with checking wiring from door or jamb. Countless people have found broken/chaffed wires.
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    47
    411
    Ken here's a recent post with a pic showing what the last two guys are telling you to look for.
    http://www.cadillacforums.com/forums...ndow-does.html
    Vernon
    Cadygrl's Avatar
    Oct 2011
    40
    137
    Thanks guys. found the problem. Three broken wires and a couple of exposed ones. Repaired broken wires and taped up bare ones and all was fixed. Checked for codes, after clearing, and there were none.
    Thanks again
    Ken
  11. Remove Advertisements
