03 Deville With P0741 Code
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 03 Deville With P0741 Code in Past Cadillac Vehicle Discussion; P0741. If the valve body had a blockage would a transmission flush help at all ? Might be an easy ...
    bobstanster's Avatar
    bobstanster is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Apr 2012
    165
    P0741. If the valve body had a blockage would a transmission flush help at all ? Might be an easy fix . If not is there a way to test the TCC selenoid ?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,362
    Re: 03 Deville
    Quote Originally Posted by bobstanster View Post
    when the P0741 code shows by itself the problem is leaking torque converter seals -
    here is a link that describes in great detail - including pics -
    the problem that causes the code -
    bottom line - the ONLY way to fix this is to drop the trans -
    and replace the torque converter and the bad seals -
    http://www.cadillacforums.com/forums...60-1998-a.html
    68
    81,897
    Re: 03 Deville
    Welcome to the P0741 club.
    P.S.
    I edited your title to be a bit more descriptive.
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    544
    Re: 03 Deville
    Never flush a transmission. Usually they do more harm than good, in my opinion. I have an 01 Deville that throws the P0741 code about every other month, it's been doing it for going on 4 years. Some cars leak by just enough to only cause the code randomly. Better off living with it. Interesting note, that same car did lock in the 741 code along with the 1860 when the TCC solenoid failed. I changed the solenoid and cleared the 1860 and it went back to giving the 741 every other month again.
    Apr 2012
    165
    Once again I have been told to flush the transmission in relation to the P0741 code . Any thoughts
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes: DO NOT FLUSH A TRANSMISSION, EVER, FOR ANY REASON!
    Besides the fact that it can potentially damage the transmission, it will do ABSOLUTELY NOTHING to fix the problem. Re read post #2. The cause is a leaking seal in the torque converter. Replacement is the ONLY solution.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,362
    Re: 03 Deville With P0741 Code
    just out of curiosity - WHO gave you this MISINFORMATION?
    what are this person's "claimed" qualifications -
    frankly - that person knows nothing about the problem -
    knows nothing about automatic transmissions -
    and knows even less about Cadillacs -
    did you read through the link I supplied?
    what part of the information in the link didn't convince you?
    68
    81,897
    Go to the Technical Archives (top left of this page in the black bar) and read up on transmission flushing. Flushing is for toilets.
  11. Remove Advertisements
