95 deville concours shift problem
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 95 deville concours shift problem in Past Cadillac Vehicle Discussion; This is a family members car, not my own. Car was having a hard shift issue from p-r-d and a ...
    luvsspeed is offline Cadillac Owners Member
    Automobile(s): 95 deville concours
    Mar 2013
    4
    Question95 deville concours shift problem
    This is a family members car, not my own. Car was having a hard shift issue from p-r-d and a bit of a stumble 1-4 gears. It does not feel like slip but a more than firm shift. Tranny was changed but issues were still there. Now I have read that it could be the ECM, just wanna weigh all possible things. I also saw there is a garage shift adapt reset that i'm 95% sure that the mechanic did not do. Is this worth a shot trying first before anything? If so what is the procedure for doing this? Also I did pull up a few codes from the display. Any help would be appreciated.
    P076 Transmission Pressure Solenoid
    S030 Speed Sensitive Steering fault
    S038 Electronic level control exhaust valve short to ground open
    S061 Right front position sensor fault
    Ranger is online now Cadillac Owners Member
    68
    81,918
    Re: 95 deville concours shift problem
    That sounds like your problem.
    Mar 2013
    4
    I've heard that those rarely go bad, that it might be the ecm. Also I find it strange that it would have the same problem before and after a transmission rebuild.
    68
    81,918
    Probably true.
    Was that sensor changed in the rebuild? DTC's are usually pretty accurate and hard to deny.
    Mar 2013
    4
    Probably true.
    Honestly I don't know and I know for a fact my uncle doesn't know.. I was just trying to look at other options other than pulling the tranny to change the solenoid. Correct me if I'm wrong but you can't just get to it by dropping the pan.
    68
    81,918
    Not if it's the one I'm thinking of at the 12:00 position in the diagram above. That one's in the side cover and it's damn near impossible to remove with the engine in the car.
    Mar 2013
    4
    Yea I'm not trying to go that route
  10. Remove Advertisements
