Need Help ASAP! Dont wanna send it to the crusher!! - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Need Help ASAP! Dont wanna send it to the crusher!! in Past Cadillac Vehicle Discussion; Its definitely getting spark on all 8 cylinders. Ill try the ICM but is there anything else before i go ...
  1. #16
    POS-DEVILLE is offline Cadillac Owners Member
    Automobile(s): 99 Deville
    Mar 2013
    31
    10
    Re: Need Help ASAP! Dont wanna send it to the crusher!!
    Its definitely getting spark on all 8 cylinders. Ill try the ICM but is there anything else before i go out and spend $200 on a new one?
    If the CKP is bad would it throw a code while cranking? Same thing with the CMP??
    have already cleaned and checked the MAF top to bottom inside and out
    yes all plug wires are in the correct location
  2. #17
    68
    81,926
    CKP sensors SHOULD set a DTC, but don't always. Not sure about the CMP sensor.
    Before spending $200 on an ICM, I'd get one much cheaper at a bone yard. Generally speaking they are pretty reliable so I wouldn't be to worried about getting one there.
  3. #18
    mike5514 is offline Cadillac Owners Enthusiast
    Automobile(s): 97sls,09dts
    79
    878
    Cam Position sensor sets the inital timing there are DMM checks for it Mike
  5. #19
    Mar 2013
    31
    10
    Quote Originally Posted by mike5514 View Post
    im assuming your talking about the on board check?
    will it not throw a code if it is bad?
    also would the cps cause a no-start?
    it wants to start but it almost seems like the ignition timing is off just enough for it not to fire....
  6. #20
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    I wouldn't go nuts checking this, that, and the other thing when you are still getting a MAF code while it's acting up. That's your only clue, use it - don't ignore it by seaching out other leads that don't exist.
    Someone with the diagnostics tree for your code might be able to help you more...
  7. #21
    79
    878
    A bad CPS should set a P0335 code and the engine will start if the crank shaft position sensors are good but the PCM will default to non sequential fuel injector operation. Health of the CPS can be checked also with a digital multimeter.
    A MAF can also be checked with a DMM battery voltage on terminal c and for ground at terminal B. Mike
  8. #22
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    46
    413
    What is the MAF code that sets when it starts?
    How does it run when it starts? Do you have to hold the throttle on it the whole time or will it idle. And will it stay running on it's own, for how long?
    Did you buy it this way or did it go bad while in your use? Was anything done to it under the hood prior to the problem or it just developed? Or do you not know anything about the history like an auction car?
    Vernon
  9. #23
    Mar 2013
    31
    10
    Quote Originally Posted by Manic Mechanic View Post
    Vernon
    code says MAF perf
    when it starts it runs poorly and i have to keep it revved or it will die. will not idle at all and it only runs (while revving) for 1-2 min then slowly the revving doesnt do anything and it dies. then 3-4 days later it with do the same thing. otherwise it just cranks and tries to start.
    bought car the way it is, previous owner said it was running then just stopped and she parked it and hasnt touched it since.
    nothing done under hood prior to the way it is now
  10. #24
    Sep 2011
    46
    413
    I meant the Code's number PXXXX. I could look it up but helping takes enough time. I can use the code to search a database.
    Most likely the catalatic convertor is clogged up. I'm not sure of that, but it is easy to check. Take the front o2 sensor out to make a pressure release hole and see if it starts and runs like normal. You can run it too long like that but it will reveal if the convertor is the problem.
    Vernon
  11. #25
    Mar 2013
    31
    10
    Vernon
    dont know the code... i cleared it and it hasnt started back up since...says no codes returned when checked now
    i pulled the o2 sensor and then pulled the cat off (pain in the ass!) and nothing changed
    i got curious and switched each plug wire around on each coil pack and it does the same thing...same sound and everything which makes me believe that it is the ignition timing that is messed up..
    so what all does the ignition timing consist of?
    coil packs.... has spark
    cam position sensor....no code
    crank position sensor(s).....no code
    ignition control module....no code
    what am i missing?
  12. #26
    68
    81,926
    Are you sure the plug wires are on correctly (proper firing order)?
  13. #27
    Mar 2013
    31
    10
    yep looks just like that
    no junk yards around me have the icm, ordering one off ebay i guess... hopefully that fixes it!
  14. Remove Advertisements
