heat stops blowing hot
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, heat stops blowing hot in Past Cadillac Vehicle Discussion; i just bought a 2001 deville and the temp gauge goes 2 bars over the middle and my heat quits ...
    cfix85 is offline Cadillac Owners Member
    Automobile(s): 2001 cadillac deville
    Mar 2013
    31
    20
    i just bought a 2001 deville and the temp gauge goes 2 bars over the middle and my heat quits blowing hot what could be the cause
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,356
    Re: heat stops blowing hot
    Quote Originally Posted by cfix85 View Post
    could be low on coolant -
    or hopefully - it's just a plugged PURGE LINE -
    do a search - it's been discussed a million times -
    Mar 2013
    31
    20
    Thanks I've done research and said the same thing about the purge line
