True or false: must get Cat from dealership only?
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Like Tree7Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, True or false: must get Cat from dealership only? in Past Cadillac Vehicle Discussion; Iv'e been having a P0420 code and remember the mech telling me i have a bad cat. Ive read that ...
    MM2Sandoval's Avatar
    MM2Sandoval is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS, R.I.P. 2001 Cadillac DeVille
    Jan 2012
    Houston, TX
    30
    180
    Iv'e been having a P0420 code and remember the mech telling me i have a bad cat. Ive read that I should NOT get AM cats because after the SES light goes away after the install, it lights back up soon after. I was told that my best bet would be to get a cat from the dealership. I dont know what price im looking at but by the looks of it, around $300 or so. So, fact or fiction?
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    46
    413
    Re: True or false: must get Cat from dealership only?
    Unless you can find an aftermarket cat that is certified for CA emmissions (and I can't from the major chains here in TX I looked for you yesterday) then yes you'll have to get a GM cat. And I looked at that also and it's $2250-$2430 list price depending on which engine you have, 9 or Y. That's a fact. Wholesale is only about 15% off that. If I were you I'd be calling the mom and pop muffler shops and seeing who'll install a CA cat with a guarantee for the best price. If you install your own and it doesn't pass your left holding the bag of woe.
    Vernon
    68
    81,902
    $300 for a CAT from a dealer? FALSE! Probably closer to $1500 - $1800. (GMpartsgiant lists it for $1800). Might check with Chris (Rippy) over there >>>>>>>>>
    Jan 2012
    Houston, TX
    30
    180
    I have a Y engine and oh lawd. Here comes the pocket drainer. Smh
    will the CA certified cat pass the emissions here? also, what is a good after market brand for a cat? im not sure what the magnaflow "universal" or "direct fit" mean
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,870
    "Universal" means "We weld it in and hope it works".
    "Direct fit" means "We bolt and weld it in and hope it works".
    Take a look in the Eastern Catalytic or RockAuto sites.
    California is the state that finds things that "are known to cause cancer" or harm humans in every kind of food, drink, material, and air - and the fed believes them, so California is largely responsible for elevated pricing on everything from toothpicks to airplanes. Which means that if the cat is "CA certified" it will pass any state, territory, country, or planet emissions regulations now and in 2234.
    Jan 2012
    Houston, TX
    30
    180
    Im looking at a Walker, its running me $168 from autozone. the only thing I find weird is the wording on this, "Ultra universalUltra Converter, Federal and California Emissions models. Not legal for sale on vehicles licensed in the state of California." The other one for $348.99 but comes with the 4 bolt welded flange. Im thinking of getting that one. I just, like you said Sub, "hope it works". I think it will solve the issue because that loud whine by the driver side front tire was bad and recently replaced it which I feel was one of 2 reasons why the cat failed. The other was a bad coil causing a misfire. I may just go ahead and get the Walker Cat for $348.99 . What do yall think?
    Feb 2006
    55,870
    Your original cat is part of the entire one-piece exhaust system. To replace the whole thing would be about $1500 if you can find one. Not many places have entire exhaust systems lying around.
    The 4-bolt flange cat is your replacement piece - it is attached to a flange/gasket/bolts at the flex joint, forward end, and welded into the (cut off) exhaust pipe just forward of the resonator. In that cat for your car there's also an O2 sensor bung just after-cat.
    Jan 2012
    Houston, TX
    30
    180
    Thank God you told me about rockauto! much cheaper and for the price of the single cat i can get the cat and the resonator with all the piping together! wow wee woo woo!
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    Try the one from bosal you could find it at rockauto.com do not get the walker direct fit only will work for 6 months the bosal one it come with the cat and the resinetor like the one from gm.
    Try bosal# 0795142 you could get at rockauto.com
    What year is your the bosal is for 2000 to 05 deville.
    Jan 2012
    Houston, TX
    30
    180
    do you know this by experience?
    grullon10's Avatar
    Dec 2012
    46
    553
    Yes . The problems that the walker has and eastern is that they are small they are are direct fit but if put them next to the oem one they look small.
    MM2Sandoval and MM2Sandoval like this.
    Jan 2012
    Houston, TX
    30
    180
    Thanks for the heads up. I was willing to spend a bit more money on a product that seemed to be better due to the price and brand. Guess not everything thats expensive with a good name will last
    Quote Originally Posted by grullon10 View Post
    Feb 2006
    55,870
    The Walker and Eastern units are the cat only - the OEM resonator stays. The CATCO replaces both cat and resonator, is 5 feet long, so it looks "bigger".
  16. #14
    Jan 2012
    Houston, TX
    30
    180
    but the BOSAL is chaper and its the same as the CATCO right?
  17. #15
    Feb 2006
    55,870
    No idea on that - never heard of (or looked for) BOSAL. If it's essentially identical, they may be one and the same. I have seen CATCO product (NOT Cadillac) as well as Eastern and Walker.
    Hmmmm ............... looks like BOSAL is an international aftermarket parts manufacturer. Website.
    If grullon10 has successfully used the CATCO on a 2001 Deville, then go for it.
  18. Remove Advertisements
