I have a 95 Cadillac Deville and my rear air shocks are not working.The compressoer is not comeing on and I believe so I understand its by the back axle in from of the muffle.I was looking at it today.I was wondering if there is a fuse for the shocks and if so where is it located so I can check that first
Thanks Olin
ELC for you - Electronic level Control. Not sure whether the 1995 has a rear underseat fuse box - check your owner's manual or download one from the sticky posts just above ^^^.
The compressors rot out and fail from ingestion of water and moisture caused by the compression process.
the Electronic Level Control fuse is in the rear - trunk - fuse block -
labeled ELC - as illustrated on page 6-67 of your Owners manual -
If your fuse isn't blown, and your car is at all similar to mine, there would be a height sensor which is a little arm/bar connected from the sensor to shock absorber by a link. If the link is missing or broken you might have my problem. That's the next thing I would check for, because it's pretty visual. But as in my case, that may only be a symptom and not a solution.
Check out this site: http://www.gmpartsdirect.com/catalog/frameset.cfm where they have some good exploded diagrams and part names. That should help identify what you're looking at down there. I'll be watching this thread with interest!
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
