98 Deville torque converter replacement - stud engine ??
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 98 Deville torque converter replacement - stud engine ?? in Past Cadillac Vehicle Discussion; Hi everyone, I'm new here I have a 98 deville with code p0741 I got the engine out Iam going ...
    alex j is offline Cadillac Owners Member
    Automobile(s): 1998 Deville
    Dec 2011
    7
    Hi everyone, I'm new here I have a 98 deville with code p0741 I got the engine out Iam going to studs the engine. Do I need to replace torque converter or Tcc solenoid sensor or both and where I can buy does parts. Thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,887
    Re: 98 deville
    Please DO NOT double post - give your question time to be answered. This was moved from Site Rules and Regulations - wrong forum. Please read the text in each forum to find out what is supposed to be asked there. Your question(s) belong in Past vehicles, Deville OR in Engines.
    You might want to let this question sit here and see if anyone chimes in - if you get no definite answers we'll move it to Engines, Northstar Performance.
    For torque converter, transmission, and engine supplies and tips, read through the pages of Cadillac Tech Tips and the stickys in the Northstar performance forums. Talk to Chris in parts at Rippy Cadillac over there >>>> and I have had good luck with www.northstarperformance.com , www.carrollcustomcadillac.com , www.huhnsolutions.com. You're in for a lot of tricky, technical work. You will NEED a real GM/Helm service manual and a comprehensive set of tools.
    68
    81,917
    Re: 98 Deville torque converter replacement - stud engine ??
    P0741 alone points to a bad seal. TC replacement is recommended. P0741 & P1860 points to the solenoid.
    Here's the explanation.
    http://www.cadillacforums.com/forums...60-1998-a.html
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    U took out motor to stud it so I assume it needs new headgaskets? AND u have p0741? Did u drop motor/trans out the bottom or pull motor out the top?
    Dec 2011
    7
    Thanks guys for reply , I removed the engine from the top, I'm going to use Northstar performance studs , the transmission still in the car.
  8. Remove Advertisements
