Fluctuating 2001 Deville fuel gauge problem
Results 1 to 15 of 15
Like Tree3Likes
  • 2 Post By vtech
  • 2 Post By talismandave
  • 2 Post By Submariner409
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Fluctuating 2001 Deville fuel gauge problem in Past Cadillac Vehicle Discussion; Any suggestions, to help with this problem would be appreiated,thanks...
    vtech is offline Cadillac Owners Member
    Automobile(s): deville
    Feb 2013
    1
    ED_DeVILLe01 and ED_DeVILLe01 like this.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Re: Fluctuating 2001 Deville fuel gauge problem
    They are designed to do that. It drops as gas is used and rises as gas is added. These fluctuations are normal and nothing to be concerned about.
    They will probably move this to the proper forum so someone can help you more. Welcome though.
    bigm57ict and bigm57ict like this.
    kingjay's Avatar
    kingjay is offline Cadillac Owners Member
    Automobile(s): 1999 Seville SLS, 2007 STS-4 V.6
    Nov 2012
    Bonita Springs, FL
    26
    72
    I believe it's the sensor that is messed up, and from what I've read you have to replace the whole fuel pump? Not sure though.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    I don't know if this is a common problem on the '01, but on some cars, the baffles in the tank come loose, allowing fuel to slosh around as you turn, go uphill, etc.
    Do you notice the fluctuations as you move, or does it happen also at a standstill?
    68
    81,917
    The baffle problem was in the early '90's Devilles.
    rcoq48 is offline Cadillac Owners Member
    Automobile(s): 2001 DTS
    Feb 2013
    Yuma, AZ
    31
    24
    Vtech,
    My 2001 DTS has this same problem:
    - Fuel Guauge stays on F until there is less than a quarter tank
    - Fuel Guage drops to E when there is less than a quarter tank
    - Fuel Guage is not at all a reliable indicator of fuel level
    - Driver must use "gal of fuel used" display on dash board to determine fuel level
    - Driver must do math to subtract from 18.5 gal tank
    - Driver must reset "gal of fuel used" display when filling gas tank
    Its a pain in the but and wish it was fixed!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    ONE of the problems affecting fuel gauge readings is sulfur deposits on the resistance slider on the fuel pump assembly: The gauge sender is attached there. (Pictures in my albums)
    A fix attempt - before spending big bucks on a new pump assembly - is to find a 20 oz. jug of Chevron TECHRON and use it with a fill-up of Top Tier gasoline (Google it). TECHRON is a powerful fuel system cleaner and is designed to remove sulfur deposits. Once in 5,000 miles !!!
    ED_DeVILLe01's Avatar
    ED_DeVILLe01 is offline Cadillac Owners Member
    Automobile(s): 2001 cadillac dts
    Feb 2013
    CHICAGO
    my 01 deville is doing samething i will try "TECHRON" let u know how it was.
    thx 4 the post guys.
    The Donald is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville delagance
    Apr 2012
    Colorado
    210
    Techron doesnt help the only thing you can do is buy a new fuel pump from Rock Auto (best price) take it to your mechanic he will drop the tank and install the new pump. I know I tried the techron bit and replacement was the only option. Been there done that.. And no I dont work for rock auto..
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by The Donald
    Techron is a possible fix, IF the problem is sulfur buildup. Read post #7.
    There's an access panel in the trunk on '00+ Devilles.
    Apr 2012
    Colorado
    210
    Oops. sorry mine is a 98 Deville
    Feb 2013
    Yuma, AZ
    31
    24
    CoolRe: Fluctuating 2001 Deville fuel gauge problem
    Quote Originally Posted by The Donald View Post
    THe Techron did not work on mine either, new fuel pump on the way from ROCKAUTO!
    68
    81,917
    I don't put much faith in that Techron either. Just replaced my youngest daughters car due to an accident. Gas gauge was a bit "sticky". I thought OK, what the hell. Against my better judgment I'll give it a shot. No change (not that any was expected).
  16. #14
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    fuel level sensors are available separately from buying a new fuel pump
    just fyi
  17. #15
    bobstanster's Avatar
    bobstanster is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Apr 2012
    165
    I had same problem , Techron did not fix it but it is worth a try . I went on eBay and purchased a brand new GM level and pump for 100 dollars . I am not a mechanic but the install is not hard to do , i have an 03 deville and you do not have to drop the tank . You access it through the trunk floor .
  18. Remove Advertisements
