The Gas Hand Is Not Working(Stuck On Full)...Any Suggestions On A Fix???
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, The Gas Hand Is Not Working(Stuck On Full)...Any Suggestions On A Fix??? in Past Cadillac Vehicle Discussion; The Gas Hand On My 1983 Cadillac Isn't Working(Stuck On Full)...Any Suggestions On A Fix??? Every once in a while ...
    Mr.83Deville is offline Cadillac Owners Member
    Automobile(s): 1983 Cadillac Deville
    Feb 2013
    Concord, NC
    26
    9
    The Gas Hand On My 1983 Cadillac Isn't Working(Stuck On Full)...Any Suggestions On A Fix??? Every once in a while whenever it feels like it, it floats down to E and Back To Full. Where do i start?
    69
    82,171
    Re: The Gas Hand Is Not Working(Stuck On Full)...Any Suggestions On A Fix???
    You probably need to replace the sending unit (in the tank).
    rayntx is offline Cadillac Owners Member
    Feb 2004
    13
    had same problem with my deville. changed out fuel pump and fixed the problem.
    The Donald is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville delagance
    Apr 2012
    Colorado
    210
    Ditto... change fuel pump its the only way..
  7. Remove Advertisements
