Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: 1996 Deville... Mechanic says head gasket repair is needed
    new_to_cadillac's Avatar
    new_to_cadillac is offline Cadillac Owners Member
    Automobile(s): 1996 Cadillac Deville Base
    Jul 2011
    Rochester, New York
    25
    16
    Unhappy 1996 Deville... Mechanic says head gasket repair is needed
    I'm not very good with cars, let alone this Cadillac. I'm a 20 year old college student who happened to be in need of a car when my grandfather wanted to sell one of his. With a deep discount on the price to sweeten the deal, I acquired this 1996 Cadillac Deville in the summer of 2011, with 58,000 miles on it.
    Fast-forward 10k miles, and here I am now. I've had a persistant oil leak for the past few weeks and after a few trips back and forth to figure out what it could be, my mechanic (who I've been with since I bought the car and is someone that I feel pretty confident with) says that there is a lot of oil at the bottom area of the engine and he says that he thinks that it really couldn't be any other part other than the head gaskets.
    I obviously know how big of a repair job this is, and my mechanic says that he's done these jobs before but they take at the very least 20 hours of labour to complete. I'm not in the position financially to pay for this to be done. To add insult to injury, the water pump needs to be replaced as it is giving up and the rack for the steering is slowly leaking.
    My mechanic says that one thing that he can do that may or may not help anything is add some additives to the oil (?) to try and block up the leak in the head gasket. Otherwise, I'm not sure what I should do.
    Is it worth spending the money on the waterpump and using these additives or should I just sell the car? I honestly cannot afford another car and I doubt I'll get much for this car despite the great condition it is otherwise (only has seen 1 winter, 68k miles, no rust, leather is in good condition, etc.) which is a shame but I guess a sign of the times.
    Thanks for your help.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Re: 1996 Deville... Mechanic says head gasket repair is needed
    Northstar head gaskets do not leak oil, additives won't help, and YOU need to get the car up on a lift, clean the underside and then look, a week later, for the source of the oil leak.
    My guess is oil filter, oil pressure sending switch, oil filter adapter, halfcase, oil pan seal, rear main bearing seal - in that order.
    When you start having mechanical problems with a 1996 Northstar, you had better have very deep pockets or a rich drunk uncle.
    (Even at Mom&Pop shop rates the water pump and steering rack will come in at over $600.)
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Step 1- Find a new mechanic.
    Head gaskets have nothing to do with oil leaks, NOTHING. There are several places that the oil may be leaking from. Some are fairly cheap, some require complete engine removal. To find the source of the leak, the engine needs to be cleaned, driven for a couple of days, and someone needs to get under there and look.
    How do you know the water pump is going? Is it making noise or leaking? Did this mechanic tell you it was bad?
    Is it really the rack that is leaking, or could that be engine oil too? Have you had to add power steering fluid?
    Oops, sub beat me.
  5. #4
    Jul 2011
    Rochester, New York
    25
    16
    As for the waterpump, that's what the mechanic said. I have seen at one instance this week coolant that had leaked from the car (not much). Also, as for the steering, I checked the level of the power steering fluid and the dip stick was barely touching any of the liquid, was about a half inch below the FULL COLD line.
    I guess I take from both of you that I should get a second opinion at another shop. He replaced my front breaks and rotors recently (I knew they needed replacing) for $250 which I thought was reasonable and he's pretty good at explaining things, or so I thought, but I guess he might not know what he's talking about.
    As for the additives, do they work better for the power steering than the head gaskets or are they all not worth trying?
    Thanks again for your help. Having such a complicated first car is a big learning curve for someone who doesn't know much mechanically speaking about cars.
  6. #5
    Sep 2010
    East Boston MA.
    29
    26,323
    Additives do nothing more than lighten your wallet, and can sometimes do more harm than good.
    A cooling system pressure test, performed with the cooling system cold, is the best way to find a small leak.
  7. #6
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    I agree with MoistCabbage - and Ranger - 100% -
    STEP #1 - find a competent mechanic -
    I wish you understood just how RIDICULOUS this "mechanic's" statement was -
    it would be VERY - VERY - VERY - RARE for ANY engine to leak oil due to a failed head gasket -
    and virtually unheard of for a Northstar motor to leak oil due to failed head gaskets -
    to make such a foolish statement - it tells me this guy known NOTHING about a Northstar motor -
    and very little about engines in general -
    FURTHERMORE - it tells me he did NOT even have the car up on a rack to look for the oil leak -
    guys like this give REAL MECHANICS a bad reputation -
  8. #7
    69
    82,284
    That was MC, but I'll join in and make it unanimous. FIND ANOTHER "MECHANIC".
  9. #8
    Jul 2011
    Rochester, New York
    25
    16
    Well, I guess it has been decided -- I'm going to go get another opinion on this. Like I said, I'm new to cars and I have no one in my immediate family or circle of friends who is gifted with knowledge of the mechanics of cars. The mechanic went into detail and that is what I took away from it, but perhaps I misconstrued what he was saying... However, I do know that two weeks ago when I brought it in the first time, he did a block compression test and it did fine according to him so thats why I'm confused with how he thinks it could be the head gaskets leaking.
    I'll be taking it in to another mechanic to see what they say, including to see if it truly needs a new waterpump. I have few or no tools at all to work on cars and have no way of getting it lifted besides the jack to change the tire so this is the only way I can do this as of now.
  10. #9
    Sep 2010
    East Boston MA.
    29
    26,323
    A compression test is not a definitive test for HG failure, that's what a block test is for. But why did he do a compression test in the first place? From what you've posted, it's pretty clear that this guy does NOT know Northstars.
    Feel free to ask us any questions you may have, even if you think it's stupid. We don't mind going into detail to clarify.
  11. #10
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Anyone who has pulled a northstar motor to fix the heads is probably aware of the block oil leakage issue. It's common while the engine is out for the head job to also do a case half oil seal repair if needed but it is extra work. Someone doing the work themselves may just shrug and go for it. But paying a mechanic to do the work is expensive. Seems like most here seem to think it is a block oil leak issue and your mechanic mighty try and yank the heads when they are ok and not the cause of the oil leak.
  12. #11
    jounier11's Avatar
    jounier11 is offline Cadillac Owners Fanatic
    Automobile(s): None for now ;)
    Dec 2012
    Tijuana, BC
    18
    208
    I Agree with, Submariner, basscatt, MoistCabbage, and Ranger:
    Get Another Mechanic cause this guy doesn't know a thing about North*'s and do a Block Test to find out if the HG's are really going.
  13. #12
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Head gaskets, leaking oil?
    Sounds more like some one has there hands in your pockets
  14. #13
    Jul 2011
    Rochester, New York
    25
    16
    Here's an update... I went to a second mom and pop mechanic and the mechanic listed these items:
    - Power Steering Reservoir is leaking
    - Water Pump is leaking
    - Head Gaskets and Intake Manifold Gaskets are leaking
    - Oil Pan Gaskets and possible Rear Main Seal
    The last phrase included on the service report... "Car is not worth put alot of money into"
    As I previously mentioned, I'm a college student and I don't have the time or money to fix the head gaskets. I could do the waterpump, but I don't really know how much time that would really buy me. The mechanic said, in contrast to the first mechanic I saw, that the waterpump seems to be functioning right now and it isn't a repair that I need to do right away. The car runs seemingly fine right now besides a power steering whine and the drops of oil (and sometimes a little coolant) found after taking the car out for a drive.
    However, I drive to a college almost 6 hours away and I need to have a reliable car so as much as I like this car, I think probably one of the best solutions is to sell it/get rid of it.
    Just curious; does anyone have a basic idea of what one can get for one of these in this condition? Besides all of those mechanical issues, the interior is in great shape overall, with the back seat looking practically new. The front seats have no rips and the paint is in good condition too. This is the car's 2nd winter being driven. I know KBB is about $2,486 for fair condition. Do you think it is better to sell it now before the problems get worse to get the most value out of it?
    Thanks for all of the input.
  15. #14
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by new_to_cadillac
    About $1,000 - $1,500
    Jus Estimating
    but that's jus my opinion
    as from my view point it's a running parts car
    Junk yards typically buy'm for around $500 - $600 round my way ( Running or Not )
  16. #15
    Sep 2007
    Wilmington, NC
    13,969
    the oil leak is most likely to be what is commonly called either 'lower block seals' or 'lower case seals' or 'case half seals'
    or something like that
    the lower end of the Northstars is known to seep oil but over the years it can develop into a true leak and the best fix involves a lot of labor resealing up the bottom end
    read this thread
    http://www.cadillacforums.com/forums...f-sealing.html
    and be sure to follow the link in post #1
  • You may not post replies
