1992 Deville bad gas mileage
Results 1 to 9 of 9
Like Tree1Likes
  • 2 Post By basscatt
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1992 Deville bad gas mileage in Past Cadillac Vehicle Discussion; I have a 1992 cadillac deville with 80k miles, back in june i did a trip to wisconsin from colorado ...
    Cadillacdevilled is offline Cadillac Owners Member
    Jan 2013
    26
    1
    I have a 1992 cadillac deville with 80k miles, back in june i did a trip to wisconsin from colorado and got 28mpg at 65-67 mpg 3 weeks ago i did the same trip from wisconsin to colorado and back to wisconsin and got 18-20mpg at all speeds and now this week getting at 17mpg at highway speeds.. no engine lights or codes and car runs great so what should i check into?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Check the Fuel Pressure Regulator. It's located on the fuel rail, and has a vacuum line running to it from the TB (another member may post a picture). Disconnect the vacuum line from it with the engine idling. Any sign of fuel indicates a ruptured diaphragm --- bad FPR.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: 1992 cadillac deville bad gas mileage
    Winter fuel is known to lower mileage too. If any sensors are bad enough they should generate a code so I would wait for that.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Re: 1992 Deville bad gas mileage
    As far as the bad mileage, you can have a minor thing such as a bad thermostat and have a drop in mpg. No codes? You need to find a FSM and learn how to use it, learn how to do diagnostics such as checking parameters which can all be brought up on your onboard diagnostics. You don't need a scanner for your car, everything is built in. Back to the fuel pressure regulator, as Ranger mentioned here is a picture.
    calvin ar is offline Cadillac Owners Fanatic
    Automobile(s): 1991 devill
    Oct 2012
    35
    116
    when my injectors went similar thing happened like that but would find out if fuel presser is right first and the fuel regulator is only 1 part of that system you have to check presser at shrader valve. also cloged fuel filter will do this some times if there is rust on out side replace as a general rule (show amount of time it has been in car)
    bessy2013's Avatar
    bessy2013 is offline Cadillac Owners Member
    Automobile(s): 1992 Cadillac Deville Touring Sedan Gold Edition
    Jan 2013
    Stuart Florida
    22
    8
    02 Filter in mine was bad. Replaced it, gained 4mpg highway and town. Course that a mechanic's job because of it needing to be lifted to get at
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by dennis93coupe
    That's the second time I've been confused with Ranger recently. Unless he's been leaving invisible posts .
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,365
    Quote Originally Posted by bessy2013 View Post
    oxygen filter? -
    it must the similar WISDOM you both share -
    Feb 2010
    Orange County, CA
    62
    2,479
    Oops!! Sorry Cabbage guess I better look at that a little more closely the next time. That's what happens when you start working 14-16 hour days at my age.
  12. Remove Advertisements
