Yellowing headlights - Page 4
Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 90
Like Tree7Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Yellowing headlights in Past Cadillac Vehicle Discussion; Originally Posted by Ranger If they are scaly and hazy on the inside, you are getting moisture in there. I ...
  1. #46
    dawiz50's Avatar
    dawiz50 is offline Cadillac Owners Member
    Automobile(s): 1998 DeVille
    May 2014
    Galveston County, Texas
    54
    30
    Re: Yellowing headlights
    If they are scaly and hazy on the inside, you are getting moisture in there. I have gotten the lenses off before and cleaned and resealed them.
    ...I think you are correct sir...when I got the car the passenger side lens was hanging on by the rubber trim...so I pulled it all the way off...cleaned it up and reattached it with silicone...then when checking the drivers side I noticed the scalling on the inside of the lens...tried to pull that one off and it would appear that someone has already glued it back on...so I think I'm 'stuck' so to speak with replacement...
  2. #47
    69
    82,383
    That is EXACTLY what I did. Before you spend money on a replacement, try removing the lens (you have nothing to loose). Once you get a small opening to insert a fine bladed screwdriver or knife blade, or maybe even a fine toothed, thin hacksaw blade, the rest will usually com along, much like opening an oyster or clam.
  3. #48
    GM_Ridin' is offline Cadillac Owners Fanatic
    Automobile(s): 2004 cadillac deville dhs
    Jan 2012
    san diego
    29
    414
    Well I guess I got ripped off on the 3M kit so I'll return it and see what price I get @ walmart. What's weird is the 3M kit I got is part #39045 but looks like the #39008.
    Also I did see spar urethane but all I was seeing was a gallon of it in the paint cans.
    I bought this:
    http://www.rustoleum.com/product-cat...-spar-urethane
    The guy there swore by it and suggested 2 coats then sand with 220 and apply 2 more coats. If this won't do the trick I'll return it for the spar urethane and mineral spirits mix.
    Also I thought about taking the headlights off when I do this because there are no outlets where I park my car (no garage). I just have to figure out where best to prop it so it stays put.
  5. #49
    69
    82,383
    That spray IS a spar urethane and will work better than mixing and wiping it on. I'd have bought that if I had seen it.
  6. #50
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,851
    Post #26
    I think I paid $10 online thanks to a tip from Bass. You can surely do better than $30.
    Here's one for $13.50 with free shipping.
    http://www.amazon.com/3M-39008-Headl...+polishing+kit
    FREE Shipping on orders over $35.
  7. #51
    69
    82,383
    Oops! Disregard the free shipping
  8. #52
    Jan 2012
    san diego
    29
    414
    They have the 3M kit @ walmart for $16.00 but it's kit 39084
  9. #53
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,851
    Quote Originally Posted by GM_Ridin' View Post
    http://www.walmart.com/ip/3M-Headlig...ingMethod=p13n
  10. #54
    knotgoalie's Avatar
    knotgoalie is offline Cadillac Owners Fanatic
    Automobile(s): 04 DHS
    Oct 2013
    Ontario, Canada
    61
    279
    All the talk about this kit and that. There are inexpensive "household" fixes that work as well. I have used the oxy-clean paste trick myself and it brought the lenses in question back to "clear and bright" but provided no on-going UV protection. Great in a pinch but you have to do it every so often.
    J.R.
  11. #55
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Nothing short of sandpaper will remove anything but light oxidation. And nothing short of power polishing will remove the sand scratches.
    Alifard likes this.
  12. #56
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,851
    Quote Originally Posted by knotgoalie View Post
    J.R.
    depending on the condition of the lens -
    anything short of the refinishing process described above
    is a total waste of time and effort -
  13. #57
    Jan 2012
    san diego
    29
    414
    My bad found it. It was locked in the glass $18.
  14. #58
    Ouly6094's Avatar
    Ouly6094 is offline Cadillac Owners Member
    Automobile(s): 2003 Deville, 2003 Passat GLX, 2003 Silverado 2500HD
    Apr 2014
    Lafontaine, Ontario, Canada
    47
    55
    Been doing headlights for years but never knew about the urethane trick...excellent results!!! Thanks Basscatt
  15. #59
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,851
    Quote Originally Posted by Ouly6094 View Post
    my pleasure -
  16. #60
    Jan 2012
    san diego
    29
    414
    Yea basscatt that was a good tip I just watched a video on YouTube with someone doing the spar urethane and mineral spirits mix and looks great.
    Ultimate Headlight Restoration: http://youtu.be/QCHCihzu-QI
    Hey have you ever used or seen results with the spar urethane in a spray can such as the one I posted?
    Also now that we know the process to restore headlights I guess the most important tip is how to maintain them.
    So what's your suggestions guys? Wax the lens every so often with a compound?
    Then eventually when the sun eats away at the uv protectant buff it out with a compound and simply apply the uv protectant again?
  17. Remove Advertisements
