Yellowing headlights - Page 3
Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 90
Like Tree7Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Yellowing headlights in Past Cadillac Vehicle Discussion; Originally Posted by rayjuswa Wouldn't it be a lot easier to just buy new headlights? ----------------------- sure - they run ...
  1. #31
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,264
    Re: Yellowing headlights
    Quote Originally Posted by rayjuswa View Post
    sure - they run between $100 and $150 each - you buying?
  2. #32
    GM_Ridin' is offline Cadillac Owners Fanatic
    Automobile(s): 2004 cadillac deville dhs
    Jan 2012
    san diego
    29
    414
    Thank you for the much needed step by step although just a FEW things are quite unclear.
    You mentioned that you use the 400, 800, 1200, 2000 and 3000 on the pads. But then you mention to use the 500, 800, 1200, 2000 sheets after each matching number pad. So am I using a 400 pad then proceeding with the continued step or was that a typo? I just want to be clear and make sure I do this right.
    Also all I have is a 18v batt drill. Any other suggestions?
  3. #33
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,997
    I have used 18v drills for this. If it has an adjustable speed, set it to the fastest setting (low torque) - in most cases that would be close to 1200 rpm, which the kit calls for. They work fine. Goes through batteries though.
  4. #34
    68
    81,760
    Easier? Yes.
    Cheaper? No
    New headlights $200 - $300
    3M kit and a can of clear spray protectant - less that $15
    From my experience there is no need for all the extra grits. The 3M kit provides 500, 800, 3000 and a packet of polishing compound. That seemed to do the job just fine.
    P.S.
    Kit calls for 1600 RPM.
    I used a variable speed corded drill. I think max speed was something like 2400. Even at max it seemed to be fine as long as you keep it moving.
  5. #35
    Avaya is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville DTS
    Jan 2014
    Iowa
    135
    Just want to chime in that I've used the 3M kit (the one made for a drill) in the past, and it works great, plus much cheaper than the others. I'm getting to the point of needing to do it to the Caddy.
  6. #36
    Jan 2012
    san diego
    29
    414
    Thanx Ranger... I do have one of these:
    http://m.harborfreight.com/7-in-vari...not%20provided
  7. #37
    68
    81,760
    That's gonna be a bit too large, plus you'll have no way to attach the provided disc pad.
    You could always pick up a cheap corded drill for $30 from Harbor Freight.
    http://www.harborfreight.com/heavy-d...ill-98179.html
  8. #38
    Jan 2012
    san diego
    29
    414
    It has 200-3350 RPM and the disk comes off. I need to see if they have a smaller one that attaches to fit the 3M pads. This should work though right?
    Didn't see your post when I posted previous post. But that may be an option I go with is a corded drill from there as long as it has the right RPM. But if they have smaller pads I may be able to use my sander/polisher because the pad I have has a velcro backing to attach pads so assuming the 3M padding is velcro it would work.
  9. #39
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,264
    Quote Originally Posted by GM_Ridin' View Post
    the buffer won't do it -
    the 3M kit uses 3" discs -
    you MUST get a variable speed 3/8 drill -
  10. #40
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    If you have a NON ORBITAL buffer, I assume you have pads and compounds?
    If so, you just need several grits of wetordry paper and you'll be all set. I use 400/600/800/1000/1500, then a heavy cutting cream, then a polish, then a swirl remover. The lenses look like glass.
  11. #41
    dawiz50's Avatar
    dawiz50 is offline Cadillac Owners Member
    Automobile(s): 1998 DeVille
    May 2014
    Galveston County, Texas
    54
    30
    Mine are scalley and hazey on the inside...guess nuttin else to do but replace them...found'em on ebay for $130 a pair...yes, I know, probably cheap foreign junk...but you get what you pay for!
    http://www.ebay.com/itm/Headlights-H...24abbe&vxp=mtr
  12. #42
    68
    81,760
    If they are scaly and hazy on the inside, you are getting moisture in there. I have gotten the lenses off before and cleaned and resealed them.
  13. #43
    Jan 2012
    san diego
    29
    414
    Well so far I got:
    3M restore kit ($30! Sheesh)
    3/8 electric drill 1500 RPM max
    water spray bottle
    I'm headed to home depot now to see if they have that spar urethane but if not any suggestions on experience of a good uv protectant? Also still not sure if I'm going to use the extra sanding methods or not basscatt suggested. The guy where I bought the 3M kit swore by this kit being good enough.
  14. #44
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,264
    they will have it -
    it is put out by MINWAX -
    called
    HELMSMAN
    SPAR URETHANE
    be sure you get the CLEAR GLOSS -
    don't forget the MINERAL SPIRITS -
    get the odorless type -
    and the DENATURED ALCOHOL -
    get a roll of 2" wide blue painters tape - 2" wide -
    take your time masking off the area around the headlights -
    the sanding discs WILL damage the rubber - and the paint -
    if you get a little off course -
    WOW - that is LIST PRICE +
    you should return it - and get it from walmart - for $15 -
    it's just the method I found that gave ME the best results -
  15. #45
    68
    81,760
    Post #26
    I think I paid $10 online thanks to a tip from Bass. You can surely do better than $30.
    Here's one for $13.50 with free shipping.
    http://www.amazon.com/3M-39008-Headl...+polishing+kit
  16. Remove Advertisements
