96 Deville Stuck in 2nd gear
Results 1 to 2 of 2
Like Tree1Likes
  • 2 Post By BeelzeBob
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 96 Deville Stuck in 2nd gear in Past Cadillac Vehicle Discussion; My 96 Deville will shift from park to reverse to neutral but no matter what drive gear you put it ...
    land75 is offline Cadillac Owners Member
    Dec 2004
    1
    Unhappy96 Deville Stuck in 2nd gear
    My 96 Deville will shift from park to reverse to neutral but no matter what drive gear you put it in its in 2nd and never up shifts or down shifts but will go into passing gear??? Any help would be appreciated
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: 96 Deville Stuck in 2nd gear
    Two words....shift solenoids. Search the forum for past posts using the search feature in the toolbar. Type "shift soleniods" into the drop down box. Read up.
    2nd gear is the hydraulic default for the trans if the shift solenoids go away. They are in the bottom pan of the trans and relatively easy to access with the trans in the car. Remove the bottom pan, remove the valve body to the bench. Split the valve body to R&R the solenoids and reinstall the valve body and pan.
    There are other things that could cause the trans to default to 2 but this is the most likely item by far.
    halfapole and halfapole like this.
