2001 DTS starter replacement
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2001 DTS starter replacement in Past Cadillac Vehicle Discussion; I too also used this write up to change my plenum and it worked out great for an occasional wrencher ...
    Rizz is offline Cadillac Owners Member
    Automobile(s): 01 DTS
    May 2011
    35
    I too also used this write up to change my plenum and it worked out great for an occasional wrencher like myself.
    Now I am having to replace the starter. I can't find a write up with this much detail, so thought I would use some of these instructions. I've read a few times that I shouldn't need to remove the fuel lines to get to the starter. Can anyone help me eliminate some of the steps in this write up for a starter replacement? Or point me in the direction............
    Roy
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,215
    Re: 2001 DTS starter replacement
    Rizz, This is not a "Cadillac Tech Tip" - it is a maintenance question. Moved to Deville.
