P0231 code
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, P0231 code in Past Cadillac Vehicle Discussion; 98 caddy deville vin-Y. turns over but no start , get code P0231 (low voltage to fuel pump) or something. ...
    timman is offline Cadillac Owners Fanatic
    Automobile(s): 1996 cadillac deville
    Jun 2010
    101
    P0231 code
    98 caddy deville vin-Y. turns over but no start , get code P0231 (low voltage to fuel pump) or something. I can get it to start if i hook 12v constant to fuel pump fuse , and runs normal.....no codes or anything. obviously not getting voltage for fuel pump relay to work. any suggestions or things i can basically check ?? fuse & relay are good. i was thinking maybe ignition 1 relay ??? Thank You , Tim
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    46
    413
    Re: P0231 code
    Try swapping the inadvertent power relay into the IGN1 relay and see if the pump fuse powers up during cranking and it runs. If so the IGN1 Relay is obviously toast.
    Vernon
    Jun 2010
    101
    Re: P0231 code
    i swapped the relays and it started,swapped them back......and it started !!! go figure !! so i replaced ignition 1 relay and fuel pump relay and fuse , and so far it has been ok.........repeat....SO FAR. i actually think i have a bad ground , or connection off the PCM. But maybe the ign relay was intrmnt.....who knows. anyone else please chime in with any comments. Thanks Vernon , Tim
  5. #4
    Sep 2011
    46
    413
    Re: P0231 code
    You're welcome Tim, yeah it could be a lot of things. But it was probably the IGN1 Relay. Sometimes bad relays will start working intermittently after I pull them out and they get tossed around a little but they rarely stay working again for long. Cleaning and tightening grounds is always a good idea when electrical problems star arising.
    Vernon
  6. #5
    Jun 2010
    101
    Re: P0231 code
    good thing about it Vernon is i got ign relay under warranty from 2 years ago when i replace it..........i keep all receipts !! cost i think $32.00 now at advance auto. tim
  7. #6
    68
    81,755
    Re: P0231 code
    Maybe your relay contacts where oxidized and you cleaned them up by removing and reinserting them.
  8. #7
    Jun 2010
    101
    Re: P0231 code
    yes ranger you never know , i also had a broken wire on the "inadvernt power relay" socket from when i replaced the socket 2 years ago , dont know what that relay is actually for or had anything to do with this problem. i should replace the ignition relay socket to be safe. tx , tim
  9. Remove Advertisements
