blown head gasket? part 3 - Page 2
Results 16 to 30 of 34
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, blown head gasket? part 3 in Past Cadillac Vehicle Discussion; Originally Posted by Ed P. The purge line was definitely blocked. I removed it from the expansion tank and then ...
  1. #16
    68
    81,748
    Re: Head gasket repair question - 2001 DTS
    Quote Originally Posted by Ed P. View Post
    The purge line was definitely blocked. I removed it from the expansion tank and then at the other end. When I pulled it off rust colored water drained out... my first sign. With how many gallons of water that have been poured into the car over the past 2 months everything in the cooling system should be crystal clear. I blew on the end of the hose, initially got some resistance and then rusty water blew out the other end. Just to be sure I fired up my air compressor and blew about 90 psi thru the hose.
    The hollow bolt was totally plugged. Initially I could not even get the coat hanger to enter. A couple of minutes of poking and jamming finally got it thru. I measured the OD of the coat hanger and followed up with a drill bit just a bit larger. Kinda' rotated that in back and forth with the help of some channel locks until I was sure it was clear. Wouldn't you now it a nice steady mix of Dex-Cool and water came streaming out.
    I'm just about to put the new expansion tank in. Is the level for the fill line that molded line on the bottom half? If so I have always been overfilling mine, could not really see it on the old yellowed/brownish lower half of the tank. Seems a bit low for a fill line.
    Ed
    Ed
    What you saw was the result of using the cooling system supplement aka sealant tabs. Keep that crap out of your cooling system. Even GM quit using it.
  2. #17
    Ed P. is offline Cadillac Owners Member
    Automobile(s): 2001 Deville DTS
    Nov 2011
    14
    blown head gasket? part 2
    Two and a half weeks ago I made a post asking about a blown head gasket. As that time I had just replaced the radiator and the car was still terribly overheating. As suggested I checked the purge line and the nipple it connected to on the left side was totally plugged. Cleaned it out, blew out the hose and the problem seemed to be solved.
    Now... I have almost a 50 mile daily commute, mostly on freeways. For the last 2 1/2 weeks the car had performed fairly normally, however three things are occurring:
    1) Twice during this time period the low coolant warning has come on. Checked the level and it was barely down, in each case a cup or two of water was all that was needed. I figured I had just purged a pocket of air somewhere.
    2) In the morning after sitting overnight when I start it up, for a few seconds it idles a bit rough and then smooths out.
    3) The Service Engine Soon light has come on. I have not yet gotten a chance to check the codes.
    And then this morning, less than an hour ago, I went out to leave for work. The starter engaged but the engine basically would not turn over. Tried it twice more, same thing. Feels just like a dead battery. Get my voltmeter and it measures like 14.10 volts at the battery... surely not the voltage of a dead battery.
    So I try the windows, they go up and done just fine. The radio plays just fine, so I try to start it again... starts up perfectly.
    Question is, do I still have a blown head gasket? I've had to top off the coolant twice, the Service Engine light is on, and could a cylinder filled with coolant overnight have prevented me from starting the car?
    Any thoughts would be appreciated.
    Ed
  3. #18
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    Re: blown head gasket? part 2
    it was probably suggested the first time - if not - do a BLOCK TEST -
    it is the difinitive test for head gasket failures in a Northstar motor -
    do a search here - it has been discussed a million times -
    there are also videos on youtube showing how-to and the expected results -
    you should also do a cooling system pressure test -
  4. #19
    PineyJustice is offline Cadillac Owners Fanatic
    Automobile(s): 2001 deville base, 2008 dts
    Apr 2012
    Michigan
    27
    310
    A leaking headgasket isn't going to stop your car from rolling over, did the starter click at all?
    Did the security light on the dashboard flash after it failed to start?
    Block test the car and put the question to rest
  5. #20
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    544
    Quote Originally Posted by PineyJustice View Post
    It will if enough coolant gets in the cylinder.
    My own experiences with 2 or possibly 3 bad northstar headgaskets has taught me that the block test is not always correct. I've had cars with a bad h/g show green and not really yellow, but had all the symptoms and after replacing the h/g went symptom free. I have tested cars with no symptoms and the fluid turned slightly green. I have my 2001 now that runs slightly hot (sometimes) going up a long hill, but does not use any coolant. And it turns the fluid green, not yellow. I plan on driving it until it gets worse, but after 50 miles a day for 3 months, if anything it has gotten slightly better. I should buy some new fluid also.
  6. #21
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    Quote Originally Posted by bigtone View Post
    due to the nature of the "magic" blue head gasket fluid -
    the test IS 99.999% accurate -
    any variance from the original BLUE color is a POSITIVE reaction -
    yellow is the strongest color change -
    green is a reaction - just a weaker one -
    blue/green is a reaction - but weaker still -
    light blue is probably the weakest reaction you can see -
    but it is still a positive reaction -
    the amount of color change is determined
    by the amount of hydrocarbons - exhaust gasses - in the coolant -
    but ANY COLOR CHANGE from the original blue color indicates bad head gaskets -
    another interesting fact -
    the magic blue fluid that has changed color -
    will - over time - return to its original blue color
    as the hydrocarbons dissipate from the fluid -
  7. #22
    dukester is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2008
    96
    Ed,
    There are many excellent posters here, and most well versed with the Northstar overheating problem.
    I followed their helpful suggestions, as I was experiencing all of the symptoms of a head gasket / head bolts problem.
    When I did the block test, the blue color changed slightly to a greenish blue (early indication of exhaust gases in the coolant).
    After considerable testing, reviews, and consideration - I had my engine rebuilt - the head gasket was not the problem, if was the head bolts coming lose from the head.
    Ed, where do you live?
  8. #23
    Nov 2011
    14
    I live in southern Orange County, California.
    When the radiator was replaced the shop did a pressure test afterwards and said it was fine. Over the past couple of weeks I have made a few coolant level checks before driving to work and when I pop the cap the system is still holding pressure at 9 AM from my drive home at 5 PM the day before.
    I will do the block test and post back.
    Ed
  9. #24
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The reason a cooling system pressure test isn't a conclusive test for HG issues, is because cylinder pressure is much higher than coolant pressure. A leak that allows 150+ PSI of combustion pressure into the cooling system, may not be sufficient enough to allow 15-18 PSI of pressurized coolant into a cylinder/s. That's why a block test is the way to go.
  10. #25
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    MC - where ya been? haven't seen you post in a while -
  11. #26
    Sep 2003
    Metro ATL
    4,854
    ....A leak that allows 150+ PSI of combustion pressure into the cooling system, may not be sufficient enough to allow 15-18 PSI of pressurized coolant into a cylinder/s.
    If the engine was used only as an air compressor, 150 PSI air pressure would not be much of a challenge for even the poorest quality head gasket.
    ....That's why a block test is the way to go.
    And a test for combustion by-products assumes combustion has taken place. Any idea what the combustion chamber pressure is during the first few nanoseconds following ignition of a compressed air/fuel mixture??
  12. #27
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    Quote Originally Posted by JimD View Post
    around 2375 PSI
  13. #28
    Apr 2012
    Michigan
    27
    310
    Assuming that number is correct that puts the down force on the piston at roughly 30,000 pounds, I knew it was a lot of force but I never thought it was quite THAT much.
  14. #29
    Sep 2003
    Metro ATL
    4,854
    Add to that, the ignition event occurs before the piston reaches TDC on the compression stroke.
  15. #30
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by basscatt
    A few personal things going on, but I'm still here. Been a little busy car wise as well. The intake manifold on my mothers Grand Marquis cracked (surprise, surprise). Replaced that.....and the plugs/wires, water pump, belt/tensioner, idler pulley and injector O-rings. Got it all back together, and the alternator wasn't charging . The alternator on the Seville also quit this week.
    Anything interesting happening here lately?
  16. Remove Advertisements
